After wrestling with a disappearing UI on one torrent client, then dealing with (an unsolveable) Segmentation Fault 11 on another, I decided to give qBittorrent a try.
Anyway, my qBittorrent client is receiving lots and lots of "Tracker Authentication" notification messages asking for a username and password. It appears that it is asking for credentials to every tracker in every torrent. Easy to correct if you have a minimal number of torrents but I am approaching the 300 torrent mark, and I expect to see this machine hit the 5000 mark and beyond. It's getting frustrating to click on cancel one or two hundred times in a timely manner since these notifications like to steal window focus. If I leave these notifications on screen, it will eventually crash qBittorrent with no error.
I have attached a screenshot of the notification in question.
To make clear, I am not using/running any private tracker or tracker than requires a username and password, and it seems to even be asking for public tracker login credentials. Each message seems to be stemming from the UDP protocol; I have DHT disabled. My guess is I have something improperly set in the settings?
Here is a dump of my qBittorrent.conf settings:
[General]
ported_to_new_savepath_system=true
[LegalNotice]
Accepted=true
[Preferences]
ExecutionLog\enabled=true
General\Locale=en_US
General\AlternatingRowColors=true
General\SystrayEnabled=true
Advanced\TrayIconStyle=0
General\CloseToTray=true
General\MinimizeToTray=true
General\StartMinimized=false
General\NoSplashScreen=true
General\ExitConfirm=false
General\PreventFromSuspend=true
Downloads\SavePath=/home/server/Completed
Downloads\TempPathEnabled=true
Downloads\TempPath=/home/server/Downloading
Downloads\AppendLabel=true
Downloads\UseIncompleteExtension=true
Downloads\PreAllocation=true
Downloads\AdditionDialog=false
Downloads\StartInPause=false
Downloads\ScanDirs=/home/server/Web Downloads
Downloads\DownloadInScanDirs=0
Downloads\TorrentExport=/home/server/Hashes
MailNotification\enabled=false
MailNotification\email=
MailNotification\smtp_server=smtp.changeme.com
MailNotification\req_ssl=false
MailNotification\req_auth=false
MailNotification\username=
MailNotification\password=
Downloads\DblClOnTorDl=0
Downloads\DblClOnTorFn=1
Connection\PortRangeMin={EDITED}
Connection\UPnP=false
Connection\GlobalDLLimit=2500
Connection\GlobalUPLimit=128
Bittorrent\uTP=true
Bittorrent\uTP_rate_limiting=false
Advanced\IncludeOverhead=false
Connection\GlobalDLLimitAlt=6080
Connection\GlobalUPLimitAlt=256
Scheduler\Enabled=true
Scheduler\start_time=@Variant(\0\0\0\xf\0m\xdd\0)
Scheduler\end_time=@Variant(\0\0\0\xf\x2\x93.\0)
Scheduler\days=0
Connection\ProxyType=1
Connection\Proxy\IP=0.0.0.0
Connection\Proxy\Port=8080
Connection\ProxyPeerConnections=false
Connection\Proxy\Authentication=false
Connection\Proxy\Username=
Connection\Proxy\Password=
Bittorrent\MaxConnecs=500
Bittorrent\MaxConnecsPerTorrent=159
Bittorrent\MaxUploadsPerTorrent=21
Bittorrent\DHT=false
Bittorrent\PeX=true
Bittorrent\sameDHTPortAsBT=true
Bittorrent\DHTPort=6881
Bittorrent\LSD=false
Bittorrent\Encryption=1
Bittorrent\MaxRatio=2
Bittorrent\MaxRatioAction=0
IPFilter\Enabled=false
Queueing\QueueingEnabled=false
Queueing\MaxActiveDownloads=3
Queueing\MaxActiveUploads=3
Queueing\MaxActiveTorrents=5
Queueing\IgnoreSlowTorrents=false
WebUI\Enabled=true
Downloads\DiskCache=64
Advanced\OutgoingPortsMin=0
Advanced\OutgoingPortsMax=0
Advanced\IgnoreLimitsLAN=true
Advanced\RecheckOnCompletion=false
General\RefreshInterval=1500
Connection\ResolvePeerCountries=true
Connection\ResolvePeerHostNames=false
Connection\MaxHalfOpenConnec=50
Advanced\SuperSeeding=false
Connection\Interface=eth0
Connection\InetAddress=
General\ProgramNotification=true
Advanced\trackerEnabled=false
Advanced\trackerPort=9000
Advanced\useSystemIconTheme=true
Advanced\confirmTorrentDeletion=true
Advanced\LtTrackerExchange=true
Advanced\AnnounceToAllTrackers=false
Connection\alt_speeds_on=true
State\size=@Size(789 591)
State\pos=@Point(556 59)
State\hSplitterSizes=129, 632
WebUI\Port=8080
WebUI\UseUPnP=true
WebUI\HTTPS\Enabled=false
WebUI\Username=Matrix
WebUI\Password_ha1=@ByteArray(f2de64bfb21284b1ffeeae0afc9a1ce4)
WebUI\LocalHostAuth=true
DynDNS\Enabled=false
DynDNS\Service=0
DynDNS\DomainName=changeme.dyndns.org
DynDNS\Username=
DynDNS\Password=
General\SpeedInTitleBar=true
RSS\RSSEnabled=false
General\ToolbarDisplayed=true
General\DeleteTorrentsFilesAsDefault=true
[AutoRun]
enabled=false
program=
server@{EDITED}:/bin$ qbittorrent
Couldn't set environment variable...
Peer ID: -qB2980-
HTTP user agent is qBittorrent v2.9.8
Catching SIGSEGV, please report a bug at http://bug.qbittorrent.org
and provide the following backtrace:
qBittorrent version: v2.9.8
stack trace:
/lib/x86_64-linux-gnu/libc.so.6 : ()+0x324f0 [0x7fac0b3a74f0]
/usr/lib/libtorrent-rasterbar.so.6 : std::_Rb_tree<libtorrent::big_number, std::pair<libtorrent::big_number const, int>, std::_Select1st<std::pair<libtorrent::big_number const, int> >, std::less<libtorrent::big_number>, std::allocator<std::pair<libtorrent::big_number const, int> > >::equal_range(libtorrent::big_number const&)+0x24 [0x7fac0dbfc2a4]
/usr/lib/libtorrent-rasterbar.so.6 : libtorrent::piece_manager::identify_data(libtorrent::big_number const&, libtorrent::big_number const&, int)+0x32 [0x7fac0dbf6622]
/usr/lib/libtorrent-rasterbar.so.6 : libtorrent::piece_manager::check_one_piece(int&)+0x305 [0x7fac0dbf76f5]
/usr/lib/libtorrent-rasterbar.so.6 : libtorrent::piece_manager::check_files(int&, int&, boost::system::error_code&)+0x66 [0x7fac0dbf7ad6]
/usr/lib/libtorrent-rasterbar.so.6 : libtorrent::disk_io_thread::operator()()+0xf31 [0x7fac0db4ac11]
/usr/lib/libboost_thread.so.1.49.0 : ()+0x10629 [0x7fac0e6f2629]
/lib/x86_64-linux-gnu/libpthread.so.0 : ()+0x6b50 [0x7fac0d82fb50]
/lib/x86_64-linux-gnu/libc.so.6 : clone()+0x6d [0x7fac0b44fa7d]
Segmentation fault
