Problem when configuring libtorrent-rasterball 0.16.10...
iZeus83
Post by iZeus83 »
Hi all.
When I'm trying to configure the file then I get this error but I don't now how to fix.
Please anyone known to fix this problem?
Checking for boost libraries:
checking for boostlib >= 1.36... yes
checking whether the Boost::System library is available... yes
configure: error: Boost.System library not found. Try using --with-boost-system=lib
I'm using Fedora 19 (x86-64) system
P.D.
I have installed qbittorrent v3.0.1.0 with comes repository of fedora.Sometimes it freezes and the second core of cpu get at 100%, I've 7 torrents seeding and 3 or 4 them takes a 100-300GB aprox.
I'm trying to update libtorrent and qbittorrent if this solves the problem.
