Downloading files dont appear
nickram
Post by nickram »
Im downloading three torrents. the first one showed up fine and succesfully downloaded the other two do not show up at all, but they are downloading as i can see the download speed is full. The directory I'm downloading the files too, show the file names.
So the UI of qbittorrent shows nothing at all.
If anybody has any idea whats causing this I'd appreciate the help, thanks
mangopower
Re: Downloading files dont appear
Post by mangopower »
Do you use labels? If it isn't a bug you might just need to press "all labels".
Hope it helps!
