Online all the time!?
Hello,
I installed qbittorrent on my debian small server and I liked it very much. I followed this guide:
http://www.linuxplained.com/install-qbi ... ui-ubuntu/
But qbittorrent only works when I put: qbittorrent-nox in the terminal using SSH. and if I close the terminal qbittorrent stops working.
How can I let qbittorrent working all the time? like tflux and utorrent?
Thank you!
Thank you!
Re: Online all the time!?
Ps.: There is a tutorial in the wiki. I didn't check beforehand, so I just wrote a generic Linux way to do it.
Here: https://github.com/qbittorrent/qBittorr ... t-X-server
I think that one is easier than the one I wrote.
================ My way (using Screen) ================
Simple (Linux, simple).
Install 'screen', and auto-start your script.
To do this:
First step: Launch a terminal. Any you want.
Install screen! (This lets you have terminal sessions. It's cool stuff, read about it.)
# sudo apt-get install screen
Then we make a cool startup script.
# nano -w start_qbittorrent.sh
The contents (just paste it):
#!/bin/bash
screen -S qbnox -d -m qbittorrent-nox
Then finally, we need to autostart it.
sudo nano -w /etc/rc.local
And add a LINE !! BEFORE !! exit 0:
su USERNAME -c /home/USERNAME/start_qbittorrent.sh
Replace USERNAME with your username.
See screenshot for what I mean:
http://i.imgur.com/XluwDb3.png
Notes:
- There are many ways to auto-start it, I think in this case rc.local is perfect.
But read about other ways here: http://askubuntu.com/questions/814/how- ... n-start-up
As it does not matter when we start it (before we log in or not.)
- As you can see we used the specific 'start_qbittorrent.sh' filename. And your home, as the file's location.
But you can change these up, however you want!
If you want a (dot) . before the filename, it will be hidden.
So I would make it called ".qbnoxstart.sh", and modify the rc.conf part. And there you go.
Lemme know if something does not work.
To do this:
#!/bin/bash
Notes:
Wow, thanks a lot
I followed the guide here: https://github.com/qbittorrent/qBittorr ... t-X-server
Did everything. Made that script. Rebooted the server too.
Then I couldn't access qbittorrent, so I entered the command line in the terminal and it worked. Once I closed the terminal the webpage stopped working
I don't know how to use command very much. But please can you show me the script? I use WinSCP and I can upload files to directories easier...but I don't know how to use nano very hard for me..
Thanks a lot for your long reply. Much appreciated.
So you did all the steps on the bottom, and it does not auto-start... right?
Try opening a terminal, and issuing: /etc/init.d/qbittorrent-nox-daemon start
See what happens. If it's some error, tell me.
(Now I'll go to sleep, but will check your reply once I wake up.) Good luck!
Yes
I entered this and I got:
start-stop-daemon: user '[USERNAME]' not found
Hmm. I'll have to edit the wiki, because it does not even mention the need to edit.
So. Open that file with a text editor.
Like so:
sudo nano -w /etc/init.d/qbittorrent-nox-daemon
And go to the USERNAME=[USERNAME] part.
Replace your [USERNAME] with your username.
So the line will look like this (for example, ofc.):
USERNAME=sergei
That should do the trick.
Like so:
USERNAME=sergei
BOOM BOOM BOOM!
Thanks a lot it worked
now I closed the terminal and all working great
But what if a day I want to stop qBittorrent?
You created this script? Niceee job bro.
Very easy to install
I just edited the wiki, but it's easy to make such scripts. It's called "init script". There are many great tutorials around.
How to stop it from running? Bottom of the page.
sudo update-rc.d -f qbittorrent-nox-daemon remove
Hello shiki, I installed qbittorrent on a dedicated server. I have the same problem. I followed all the guide and installed the same file in init.d
But I'm getting problem:
root@ks396986:~# sudo update-rc.d qbittorrent-nox-daemon defaults
update-rc.d: using dependency based boot sequencing
root@ks396986:~# /etc/init.d/qbittorrent-nox-daemon start
-bash: /etc/init.d/qbittorrent-nox-daemon: /bin/sh^M: bad interpreter: No such file or directory
But the file is there. 100%.
For now I'm using qbittorrent on my small VPS.
Thanks!
Thanks!
Something is messed up with your qbittorrent-nox-daemon file.
Try to download the file and check it with Notepad++.
(It complains about the very first line.)
Try downloading the file with wget, instead of copy-paste it with a text editor or something.
BOOM BOOM it worked
But
sudo wget -O /etc/init/qbittorrent-nox-daemon http://launchpadlibrarian.net/38905385/qbittorrent
Is right?
Shouldn't be init.d? and not just init?
But
Is right?
You are right, it's a typo in that command. (well, not a typo. I had a VM without X. While I did try out the commands, I didn't copy-paste them, sorry. (The wget command would fail anyway if there is no such dir.))
update: fixed the wiki
My friend shiki, I have a small server from OVH. I have torrentflux installed and qbittorrent. Both are the same for them, easy to use.
But which one is better for the CPU/RAM?
torrentflux is crap.
just install rtorrent, that's the lightest client.
