[unofficial]qBittorrent git master builds: 3.2.0alpha_20150308_19b9a84
Link to latest: http://qbforums.shiki.hu/index.php/topi ... l#msg15534
ORIGINAL POST BELOW
Here is a build of qBittorrent 3.2.0alpha_25122013 from git master with:
boost 1.55
libtorrent 0.16.13(RC_0_16 actually)
openssl: 1.0.1e
qt: 4.8.5
Built using MSVC2008.
This contains a possible fix for when qbt loses the settings.
Use the attached torrent first.
http://builds.shiki.hu/qbittorrent_3.2. ... _setup.exe
qbittorrent_3.2.0alpha_25122013_setup.torrent
(6.6 KiB) Downloaded 1600 times
Last edited by sledgehammer_999 on Sat Mar 07, 2015 11:17 pm, edited 1 time in total.
Re: [unofficial]qBittorrent git master builds: 3.2.0alpha_25122013
Thanks sledge, I was hoping for a build with 16.13 amd here it is. Lets test it :).
Edit: New ''Statistics'' window under ''Tools'', nice :).
The stats are a little bit inaccurate. Dayman is working on a fix.
I see :). After 1 day usage I can say that it is stable till now (still running).
Thanks sledge & Dayman for your efforts.
Re: [unofficial]qBittorrent git master builds: 3.2.0alpha_20140127
boost 1.55
libtorrent 0.16.13+svn9640
openssl: 1.0.1e
qt: 4.8.5
Feature: Samba/network locations support (Gelmir)
Last edited by sledgehammer_999 on Mon Jan 27, 2014 9:44 pm, edited 1 time in total.
Thanks sledge & Dayman! Just installed and running already :D. I will report back after testing it a while how it goes.
tekko
Post by tekko »
Just a suggestion... Include the last commit hash (i.e. a5a0ca7159) as the build info in the post along with the installer. It's easier for the others to keep track and search.
Thanks to everyone who has helped developing the new build.
This alpha (or call it current stable if you ask me :P) is with one word great :)!. Im yet to find anything that is faulty or bugged, its as stable as it can get. Also after several reboots and restarting since my last post here I can say that the settings bug is definitly gone.
ciaobaby
Post by ciaobaby »
There is a glitch with the name column on the content tab, raised issue #1360 at Git.
And the installed search engines have dropped out and had to be installed again, cause as yet unknown.
Here is a build of qBittorrent 3.2.0alpha sha1 33b0a2b55f from git master with:
boost 1.55
libtorrent 0.16.14+svn9686
openssl: 1.0.1e
qt: 4.8.5
Built using gcc 4.8.0.
It fixes the crash when preallocation is enabled.
Re: [unofficial]qBittorrent git master builds: 3.2.0alpha_20140208
Thanks mate.
Edit: This alpha sometimes refuses to resume and seed 14GB torrent, it shows on the log that its refused. But its rechecking fine and it happened twice now. v3.1.8 doesn't do this.
tekko
Post by tekko »
The PDB file is not included with this alpha...
What is the log message?
The pdb file is missing because this is build with gcc. gcc builts the executable a lot faster. The msvc build does Link Time Code Generation, which is dead slow on my pc.
It only shows at the start from qBit that the torrent file is refused and that it will recheck. The torrent stays at 0% and doesn't starts rechecking automaticly. So I choose to recheck and it gets to 100% again and starts seeding normally. This happened twice already with the same torrent while the others are working fine which is weird. Im very sure that the torrent is not corrupt or incomplete. I've reinstalled v3.1.8 and it works without errors in the log with the same torrent. I would like to share the torrent file but its a private one so I can't.
I installed the alpha again and will see if it happens again.
This is what the log says:
10/02/2014 09:49:12 - Reason: [Torrent Name] fast resume rejected: mismatching file size
10/02/2014 09:49:12 - Fast resume data was rejected for torrent [Torrent Name], checking again...
When I do recheck and restart qBit I get this error and torrent shows 0% again but it rechecks fully to 100%. As I said this is not happening with v3.1.8. Also im using the setting to copy the torrent to a folder after adding  and it doesn't make one with this torrent.
