percentage isnt actually a percentage
Allwynd
Post by Allwynd »
hey you guys, i just downloaded the newest iteration of qBittorrent - 3.1.8 and it was fine yesterday, and i think this morning too, but now i started it up and i noticed that on the progress bar, the percentage sign is gone
its not an issue and i wont die because of it, im just curious if there is a known cure to it?
as well as i have this issue that after i close qBittorrent sometimes the next time i start it, like all the settings i made were erased and the program starts with default settings:
the settings menu doesnt have the items scaled one under another, i have to drag the border, to make it look like that
my downloads location is back to C:\something...
and my window size, postition and the columns in the download screen are back to normal
i wont post a screenshot though, because since updating to 3.1.8 it hasnt happened (yet)
Re: percentage isnt actually a percentage
Im not sure if it is supposed to be like that or perhaps he ''forgot'' it, thats something that sledge maybe can answer. But like you said with or without the sign isn't a big issue.
About the settings issue; This was known with v3.1.5 (some people had it with earlier versions also) but this is fixed with 3.1.8. See here for more information: http://qbforums.shiki.hu/index.php/topic,2327.0.html
definitely a regression. I reworked the code that printed decimal numbers and probably deleted the percentage sign in the process. please report to the bug tracker so I won't forget about this.
Allwynd
Post by Allwynd »
hey, you guys, thanks for the quick responses, i made a report, i hope it makes sense, because i dont do that kind of stuff, i just did it because qBittorrent is too good
http://www.github.com/qbittorrent/qBitt ... ssues/1392
Well done Allwynd :).
Im already used to it and somehow I like it :P.
Allwynd
Post by Allwynd »
yay! i did good (n_n)
zeomal
Post by zeomal »
This is even applicable to the 64-bit Windows Qt5 builds provided by Dayman. I didn't notice this until I had read this post.
Currently using the latest 3.2.0 alpha experimental builds.
Screenshot 1.PNG (1.69 KiB) Viewed 1539 times
