qBit 3.1.9 exe runtime error
Is there anything i can do to fix this, and how do i even diagnose it when the error is so vage. It just says "runtime error qbittorrent.exe, requested to close in an unusual way" and the program crashes.
Over the past 2 days it has happened 5 times, and just now 2 times in less than 10 min.
Re: qBit 3.1.9 exe runtime error
it just keeps crashing again & again & again, around 10 crashes to day.
Can you download and run it through "windbg"? Then do a
in the command box.!analyze -v
Ok let me expand on this.
1. WinDbg and select File->Open executable. Select qbittorrent.exe
2. A new subwindow will open.
3. In the main windows select Debug->Go and qbt will start
4. Now you will have to wait until the crash happens.
5. After that, in the subwindow you will be able to input commands(at the bottom).
6. Issue "!analyze -v" and hopefully some useful info will be presented.
"3. In the main windows select Debug->Go and qbt will start" It didn't start so i just started it manually.
qbt needs to run from inside the debugger.
Why didn't it start? Does the subwidows show something?
If you start it manually from outside the debugger, then attach to it from windbg(file->attach to a process...)
This is there before i press go, but after i've choosen the exe.
Executable search path is:
ModLoad: 00000000`00f90000 00000000`01e3b000 qbittorrent.exe
ModLoad: 00000000`77370000 00000000`77519000 ntdll.dll
ModLoad: 00000000`77550000 00000000`776d0000 ntdll32.dll
ModLoad: 00000000`74120000 00000000`7415f000 C:\Windows\SYSTEM32\wow64.dll
ModLoad: 00000000`740c0000 00000000`7411c000 C:\Windows\SYSTEM32\wow64win.dll
ModLoad: 00000000`740b0000 00000000`740b8000 C:\Windows\SYSTEM32\wow64cpu.dll
(105c.da8): Break instruction exception - code 80000003 (first chance)
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
ntdll!CsrSetPriorityClass+0x40:
00000000`7741cb70 cc int 3
When i press go it says this, but it doesn't start.
0:000> g
ModLoad: 00000000`77250000 00000000`7736f000 WOW64_IMAGE_SECTION
ModLoad: 00000000`76bb0000 00000000`76cc0000 WOW64_IMAGE_SECTION
ModLoad: 00000000`77250000 00000000`7736f000 NOT_AN_IMAGE
ModLoad: 00000000`77150000 00000000`7724a000 NOT_AN_IMAGE
ModLoad: 00000000`76bb0000 00000000`76cc0000 C:\Windows\syswow64\kernel32.dll
ModLoad: 00000000`75f40000 00000000`75f87000 C:\Windows\syswow64\KERNELBASE.dll
ModLoad: 00000000`720b0000 00000000`7219b000 C:\Windows\SysWOW64\dbghelp.dll
ModLoad: 00000000`76060000 00000000`7610c000 C:\Windows\syswow64\msvcrt.dll
ModLoad: 00000000`76f10000 00000000`76fb0000 C:\Windows\syswow64\ADVAPI32.dll
ModLoad: 00000000`75ec0000 00000000`75ed9000 C:\Windows\SysWOW64\sechost.dll
ModLoad: 00000000`75dd0000 00000000`75ec0000 C:\Windows\syswow64\RPCRT4.dll
ModLoad: 00000000`74f70000 00000000`74fd0000 C:\Windows\syswow64\SspiCli.dll
ModLoad: 00000000`74f60000 00000000`74f6c000 C:\Windows\syswow64\CRYPTBASE.dll
ModLoad: 00000000`75060000 00000000`75caa000 C:\Windows\syswow64\SHELL32.dll
ModLoad: 00000000`76cd0000 00000000`76d27000 C:\Windows\syswow64\SHLWAPI.dll
ModLoad: 00000000`74fd0000 00000000`75060000 C:\Windows\syswow64\GDI32.dll
ModLoad: 00000000`77050000 00000000`77150000 C:\Windows\syswow64\USER32.dll
ModLoad: 00000000`76d40000 00000000`76d4a000 C:\Windows\syswow64\LPK.dll
ModLoad: 00000000`76fb0000 00000000`7704d000 C:\Windows\syswow64\USP10.dll
ModLoad: 00000000`74230000 00000000`74255000 C:\Windows\SysWOW64\POWRPROF.dll
ModLoad: 00000000`765a0000 00000000`7673d000 C:\Windows\syswow64\SETUPAPI.dll
ModLoad: 00000000`76790000 00000000`767b7000 C:\Windows\syswow64\CFGMGR32.dll
ModLoad: 00000000`76360000 00000000`763ef000 C:\Windows\syswow64\OLEAUT32.dll
ModLoad: 00000000`76d50000 00000000`76eac000 C:\Windows\syswow64\ole32.dll
ModLoad: 00000000`76150000 00000000`76162000 C:\Windows\syswow64\DEVOBJ.dll
ModLoad: 00000000`763f0000 00000000`7646b000 C:\Windows\syswow64\COMDLG32.dll
ModLoad: 00000000`70c40000 00000000`70dde000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
ModLoad: 00000000`76190000 00000000`761f0000 C:\Windows\syswow64\IMM32.dll
ModLoad: 00000000`761f0000 00000000`762bc000 C:\Windows\syswow64\MSCTF.dll
ModLoad: 00000000`71a20000 00000000`71a52000 C:\Windows\SysWOW64\WINMM.dll
ModLoad: 00000000`75f90000 00000000`75fc5000 C:\Windows\syswow64\WS2_32.dll
ModLoad: 00000000`75f30000 00000000`75f36000 C:\Windows\syswow64\NSI.dll
ModLoad: 00000000`73e40000 00000000`73e7c000 C:\Windows\SysWOW64\MSWSOCK.dll
ModLoad: 00000000`75cb0000 00000000`75dd0000 C:\Windows\syswow64\CRYPT32.dll
ModLoad: 00000000`76180000 00000000`7618c000 C:\Windows\syswow64\MSASN1.dll
(105c.da8): WOW64 breakpoint - code 4000001f (first chance)
First chance exceptions are reported before any exception handling.
This exception may be expected and handled.
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll32.dll -
ntdll32!LdrVerifyImageMatchesChecksum+0x96c:
775f103b cc int 3
Attach to process is greyed out.
Oh wait, i just clicked "Go" again, because i was thinking maybe i choose the exe, start the process and then press go. It added this & brought qbittorrent to the front.
0:000:x86> g
ModLoad: 00000000`72280000 00000000`72300000 C:\Windows\SysWOW64\uxtheme.dll
ModLoad: 00000000`71d40000 00000000`71d53000 C:\Windows\SysWOW64\dwmapi.dll
ModLoad: 00000000`03510000 00000000`0415a000 C:\Windows\SysWOW64\shell32.dll
ModLoad: 00000000`03510000 00000000`03620000 C:\Windows\SysWOW64\kernel32.dll
ModLoad: 00000000`03510000 00000000`03610000 C:\Windows\SysWOW64\user32.dll
ntdll!ZwTerminateProcess+0xa:
00000000`773c157a c3 ret
Edit:
Okay i see what's going on, when i hit "go" it start a qbittorrent process that only uses 1.2mb and has no gui, but it's there in taskmanager.
The "real" qbit doesn't pop up before i manually start the program.
0:000> g
775f103b cc int 3
0:000:x86> g
Edit:
When you press "go" input in the command "!analyze -v" after it has finished scrolling.
If you want to attach to process then you must not click "open executable"
0:000> !analyze -v
Last event: 1040.13dc: Exit process 0:1040, code 0
debugger time: Sat Mar 15 16:55:23.702 2014 (UTC + 1:00)
Will try "attach to process" and see what happens.
*** wait with pending attach
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
ModLoad: 00000000`01060000 00000000`01f0b000 C:\Program Files (x86)\qBittorrent\qbittorrent.exe
ModLoad: 00000000`77370000 00000000`77519000 C:\Windows\SYSTEM32\ntdll.dll
ModLoad: 00000000`77550000 00000000`776d0000 ntdll.dll
ModLoad: 00000000`76bb0000 00000000`76cc0000 KERNEL32.dll
ModLoad: 00000000`75f40000 00000000`75f87000 KERNELBASE.dll
ModLoad: 00000000`720b0000 00000000`7219b000 dbghelp.dll
ModLoad: 00000000`76060000 00000000`7610c000 msvcrt.dll
ModLoad: 00000000`76f10000 00000000`76fb0000 ADVAPI32.dll
ModLoad: 00000000`75ec0000 00000000`75ed9000 SECHOST.dll
ModLoad: 00000000`75dd0000 00000000`75ec0000 RPCRT4.dll
ModLoad: 00000000`74f70000 00000000`74fd0000 SspiCli.dll
ModLoad: 00000000`74f60000 00000000`74f6c000 CRYPTBASE.dll
ModLoad: 00000000`75060000 00000000`75caa000 SHELL32.dll
ModLoad: 00000000`76cd0000 00000000`76d27000 SHLWAPI.dll
ModLoad: 00000000`74fd0000 00000000`75060000 GDI32.dll
ModLoad: 00000000`77050000 00000000`77150000 USER32.dll
ModLoad: 00000000`76d40000 00000000`76d4a000 LPK.dll
ModLoad: 00000000`76fb0000 00000000`7704d000 USP10.dll
ModLoad: 00000000`74230000 00000000`74255000 POWRPROF.dll
ModLoad: 00000000`765a0000 00000000`7673d000 SETUPAPI.dll
ModLoad: 00000000`76790000 00000000`767b7000 CFGMGR32.dll
ModLoad: 00000000`76360000 00000000`763ef000 OLEAUT32.dll
ModLoad: 00000000`76d50000 00000000`76eac000 ole32.dll
ModLoad: 00000000`76150000 00000000`76162000 DEVOBJ.dll
ModLoad: 00000000`763f0000 00000000`7646b000 COMDLG32.dll
ModLoad: 00000000`70c40000 00000000`70dde000 COMCTL32.dll
ModLoad: 00000000`76190000 00000000`761f0000 IMM32.dll
ModLoad: 00000000`761f0000 00000000`762bc000 MSCTF.dll
ModLoad: 00000000`71a20000 00000000`71a52000 WINMM.dll
ModLoad: 00000000`75f90000 00000000`75fc5000 WS2_32.dll
ModLoad: 00000000`75f30000 00000000`75f36000 NSI.dll
ModLoad: 00000000`73e40000 00000000`73e7c000 MSWSOCK.dll
ModLoad: 00000000`75cb0000 00000000`75dd0000 CRYPT32.dll
ModLoad: 00000000`76180000 00000000`7618c000 MSASN1.dll
ModLoad: 00000000`72280000 00000000`72300000 UxTheme.dll
ModLoad: 00000000`71d40000 00000000`71d53000 dwmapi.dll
ModLoad: 00000000`73cd0000 00000000`73ce7000 USERENV.dll
ModLoad: 00000000`73d50000 00000000`73d5b000 profapi.dll
ModLoad: 00000000`721f0000 00000000`72206000 CRYPTSP.dll
ModLoad: 00000000`721b0000 00000000`721eb000 RSAENH.dll
ModLoad: 00000000`741f0000 00000000`741f6000 WSHIP6.dll
ModLoad: 00000000`73d40000 00000000`73d45000 WSHTCPIP.dll
ModLoad: 00000000`72360000 00000000`723a4000 DNSAPI.dll
ModLoad: 00000000`73d70000 00000000`73d8c000 IPHLPAPI.DLL
ModLoad: 00000000`73d60000 00000000`73d67000 WINNSI.DLL
ModLoad: 00000000`72300000 00000000`72306000 rasadhlp.dll
ModLoad: 00000000`72310000 00000000`72348000 fwpuclnt.dll
ModLoad: 00000000`721a0000 00000000`721ae000 RpcRtRemote.dll
ModLoad: 00000000`71130000 00000000`711b4000 COMCTL32.dll
(c34.608): Break instruction exception - code 80000003 (first chance)
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\ntdll.dll -
ntdll!DbgBreakPoint:
00000000`773c0590 cc int 3
I guess i just let it be and hope for something to happen and then use "!analyze -v"
Edit:
Seems like when i "attach to process" it makes qbittorrent.exe stop working, i can't interact with the program, if i stop debug it closes the process as well.
Edit:
[quote="fusk"]
Edit:
Sorry I didn't mention this. You will need to press go after you attach.
PS: What Windows version are you using?
Edit:
Ah, much better, now it says "Debuggee is running..."
Win7 x64
Win7 x64
http://pastebin.com/yfbYWUpq
Crashed not long after, same thing. I/O error "not enough space" Then followed by unresponsive UI, using stop debug closed the process.
Did it allow you to enter !analyze -v before you stoped the debuging?Crashed not long after, same thing. I/O error "not enough space" Then followed by unresponsive UI, using stop debug closed the process.
The debugger freezes the program when an exception occur so you can investigate. Probably that's the reason qbt became unresponsive.
Okay, here we go. Think this might be the important part.
GetPageUrlData failed, server returned HTTP status 404
URL requested: http://watson.microsoft.com/StageOne/qb ... Retriage=1
FAULTING_IP:
KERNELBASE!RaiseException+58
75f4c41f c9 leave
EXCEPTION_RECORD: ffffffffffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 0000000075f4c41f (KERNELBASE!RaiseException+0x0000000000000058)
ExceptionCode: e06d7363 (C++ EH exception)
ExceptionFlags: 00000001
NumberParameters: 3
Parameter[0]: 0000000019930520
Parameter[1]: 0000000003f7f434
Parameter[2]: 0000000000e661a0
FAULTING_THREAD: 0000000000001068
DEFAULT_BUCKET_ID: WRONG_SYMBOLS
PROCESS_NAME: qbittorrent.exe
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
FAULTING_MODULE: 0000000077370000 ntdll
DEBUG_FLR_IMAGE_TIMESTAMP: 5311d18e
ERROR_CODE: (NTSTATUS) 0xe06d7363 - <Unable to get error code text>
EXCEPTION_CODE: (NTSTATUS) 0xe06d7363 - <Unable to get error code text>
EXCEPTION_PARAMETER1: 0000000019930520
EXCEPTION_PARAMETER2: 0000000003f7f434
EXCEPTION_PARAMETER3: 0000000000e661a0
MOD_LIST: <ANALYSIS/>
PRIMARY_PROBLEM_CLASS: WRONG_SYMBOLS
BUGCHECK_STR: APPLICATION_FAULT_WRONG_SYMBOLS_ZEROED_STACK
LAST_CONTROL_TRANSFER: from 0000000000800946 to 0000000075f4c41f
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
03f7f3ec 00800946 e06d7363 00000001 00000003 KERNELBASE!RaiseException+0x58
03f7f424 007fc25f 03f7f434 00e661a0 008b14a0 qbittorrent!_CxxThrowException+0x48 [f:\dd\vctools\crt_bld\self_x86\crt\prebuild\eh\throw.cpp @ 161]
03f7f440 00132464 00200000 014c0000 00000000 qbittorrent!operator new+0x64 [f:\dd\vctools\crt_bld\self_x86\crt\src\new.cpp @ 63]
03f7f458 0012ebb7 00200000 00000000 00200000 qbittorrent!std::_Allocate<char>+0x15 [c:\program files\microsoft visual studio 9.0\vc\include\xmemory @ 43]
03f7f478 0012d04e 47f0fa58 00000000 00200000 qbittorrent!std::vector<char,std::allocator<char> >::_Insert_n+0x72 [c:\program files\microsoft visual studio 9.0\vc\include\vector @ 1173]
03f7f4b0 007c39ca 00200000 00000000 5443e020 qbittorrent!std::vector<char,std::allocator<char> >::resize+0x43 [c:\program files\microsoft visual studio 9.0\vc\include\vector @ 719]
03f7f4d4 00754228 066cb232 00000014 03f7f50c qbittorrent!libtorrent::inflate_gzip+0x4a
03f7f54c 0075e518 00000000 00f0b998 066cb232 qbittorrent!libtorrent::http_connection::callback+0x108
03f7f650 00757260 03f7f72c 00000005 3626f470 qbittorrent!libtorrent::http_connection::on_read+0x488
03f7f6c8 00745a17 00000000 00f0b998 00000022 qbittorrent!boost::asio::ssl::detail::io_op<libtorrent::http_stream,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::_bi::bind_t<void,boost::_mfi::mf2<void,libtorrent::http_connection,boost::system::error_code const &,unsigned int>,boost::_bi::list3<boost::_bi::value<boost::shared_ptr<libtorrent::http_connection> >,boost::arg<1>,boost::arg<2> > > >::operator()+0x1f0
03f7f6dc 0074aeae 03f7f714 03f7f73c 02a4d305 qbittorrent!boost::asio::asio_handler_invoke<boost::asio::detail::binder2<boost::asio::ssl::detail::io_op<libtorrent::socks5_stream,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::_bi::bind_t<void,boost::_mfi::mf2<void,libtorrent::http_connection,boost::system::error_code const &,unsigned int>,boost::_bi::list3<boost::_bi::value<boost::shared_ptr<libtorrent::http_connection> >,boost::arg<1>,boost::arg<2> > > >,boost::system::error_code,unsigned int> >+0x17
03f7f764 006c9aa6 0323c250 3626f438 03f7f7a8 qbittorrent!boost::asio::detail::win_iocp_socket_recv_op<boost::asio::mutable_buffers_1,boost::asio::ssl::detail::io_op<libtorrent::socks5_stream,boost::asio::ssl::detail::read_op<boost::asio::mutable_buffers_1>,boost::_bi::bind_t<void,boost::_mfi::mf2<void,libtorrent::http_connection,boost::system::error_code const &,unsigned int>,boost::_bi::list3<boost::_bi::value<boost::shared_ptr<libtorrent::http_connection> >,boost::arg<1>,boost::arg<2> > > > >::do_complete+0xee
03f7f7cc 006ca4c8 00000001 03f7f820 02a4d215 qbittorrent!boost::asio::detail::win_iocp_io_service::do_one+0x1a6
03f7f824 006bc828 02a4ddc5 00000000 03289770 qbittorrent!boost::asio::detail::win_iocp_io_service::run+0xb8
03f7f888 76bc336a 03289770 03f7f8d4 77589f72 qbittorrent!boost::asio::detail::win_thread_function+0x48
03f7f894 77589f72 03289770 75c331e5 00000000 KERNEL32!BaseThreadInitThunk+0x12
03f7f8d4 77589f45 00801a89 03289770 00000000 ntdll_77550000!RtlInitializeExceptionChain+0x63
03f7f8ec 00000000 00801a89 03289770 00000000 ntdll_77550000!RtlInitializeExceptionChain+0x36
FOLLOWUP_IP:
qbittorrent!operator new+64 [f:\dd\vctools\crt_bld\self_x86\crt\src\new.cpp @ 63]
007fc25f cc int 3
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: qbittorrent!operator new+64
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: qbittorrent
IMAGE_NAME: qbittorrent.exe
STACK_COMMAND: ~4s ; kb
FAILURE_BUCKET_ID: WRONG_SYMBOLS_e06d7363_qbittorrent.exe!operator_new
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOne/qb ... Retriage=1
Followup: MachineOwner
Do you want top to bottom ? http://paste.ubuntu.com/7096652/
FAULTING_IP:
75f4c41f c9 leave
NumberParameters: 3
STACK_TEXT:
FOLLOWUP_IP:
007fc25f cc int 3
