3.1.9 - Execution Log -> Blocked IPs
neuron
Post by neuron »
Ubuntu 64 bit
"Successfully parsed the provided IP filter: 273695 rules were applied."    ok
If I scroll the IP's, the CPU get 100 % and I need restart.
Best regards,
Neuron
Re: 3.1.9 - Execution Log -> Blocked IPs
Does it stay at 100% even if you close the log? (view->execution log)
What qbt version are you using?
neuron
Post by neuron »
[quote="sledgehammer_999"]
Please read the subject:  Re: 3.1.9 - ..........
I can't close QBT because the CPU - 100 % and i can't interact with QBT .... no answer
Regards,
Neuron
Do you see a flood of blocked IPs in the "Blocked IPs" tab? If yes, then it seems that those blocked IPs are actively trying to connect to you and libtorrent refuses. Libtorrent emits a signal that it blocked that certain IP and qbt logs it. But if those IPs try again and again then qbt will continually try to update the log and thus apps will become unresponsive. Can you tell if that is the case?
neuron
Post by neuron »
Since I have several active torrents ... there is several new IP ... insert.
But in < 3.17, all was fine and the scroll is normal.
In last 2 version I can't move the page ... and then ... the App don't respond.
Best Regards,
Neuron
Is it possible for you to retry with 3.1.5? (3.1.6 and 3.1.7 had broken sources)
neuron
Post by neuron »
The versions I used:
qbittorrent-3.0.8,    3.0.9,    3.0.10,        3.0.11,    3.1.0,    3.1.2,    3.1.3,    3.1.8
Best Regards,
Neuron
[quote="neuron"]
[quote="neuron"]
So, which is true? Did that happen with all the listed version or only 3.1.8?
neuron
Post by neuron »
[quote="neuron"]
[quote="neuron"]
I answer in previous  .... Until 3.1.3
In 3.1.8 and 3.19    I can't scroll
