Wasted Downloads
coldlm
Wasted Downloads
Post by coldlm »
I think i need an IPfilter or something like that, is there a filter i can use for qbit!
because sometimes  it just keeps looping never finishes the download!
Re: Wasted Downloads
libtorrent should autoban some bad peers. View->execution log->blocked ips Is there anything in there?
coldlm
Post by coldlm »
08/07/2003 08:58:09 - External IP: 197.205.45.119
08/07/2003 08:46:47 - Successfully parsed the provided IP filter: 0 rules were applied.
08/07/2003 08:46:46 - Embedded Tracker [OFF]
08/07/2003 08:46:46 - Encryption support [ON]
08/07/2003 08:46:46 - Local Peer Discovery support [ON]
08/07/2003 08:46:46 - PeX support [ON]
08/07/2003 08:46:46 - DHT support [ON], port: UDP/6881
08/07/2003 08:46:46 - Anonymous mode [OFF]
08/07/2003 08:46:46 - HTTP user agent is qBittorrent v3.1.8
08/07/2003 08:46:46 - UPnP / NAT-PMP support [ON]
08/07/2003 08:46:46 - Options were saved successfully.
08/07/2003 08:04:39 - Successfully parsed the provided IP filter: 0 rules were applied.
08/07/2003 08:04:37 - Embedded Tracker [OFF]
08/07/2003 08:04:37 - Encryption support [ON]
08/07/2003 08:04:37 - Local Peer Discovery support [ON]
08/07/2003 08:04:37 - PeX support [ON]
08/07/2003 08:04:37 - DHT support [ON], port: UDP/6881
08/07/2003 08:04:37 - Anonymous mode [OFF]
08/07/2003 08:04:37 - HTTP user agent is qBittorrent v3.1.8
08/07/2003 08:04:37 - UPnP / NAT-PMP support [ON]
08/07/2003 08:04:37 - Options were saved successfully.
08/07/2003 06:41:25 - 'Orange Is The New Black Season 1 Complete 480p HDTV x264 [Multi-Sub] [DexzAery]' was removed from transfer list.
08/07/2003 04:22:26 - 'Flipped (2010)' was removed from transfer list.
08/07/2003 04:21:52 - 'House of Cards Season 1' was removed from transfer list and hard disk.
08/07/2003 04:02:10 - Pausing torrent Orange Is The New Black Season 1 Complete 480p HDTV x264 [Multi-Sub] [DexzAery]...
08/07/2003 04:02:10 - Orange Is The New Black Season 1 Complete 480p HDTV x264 [Multi-Sub] [DexzAery] reached the maximum ratio you set.
07/07/2003 20:41:25 - Embedded Tracker [OFF]
07/07/2003 20:41:25 - Encryption support [ON]
07/07/2003 20:41:25 - Local Peer Discovery support [ON]
07/07/2003 20:41:25 - PeX support [ON]
07/07/2003 20:41:25 - DHT support [ON], port: UDP/6881
07/07/2003 20:41:25 - Anonymous mode [OFF]
07/07/2003 20:41:25 - HTTP user agent is qBittorrent v3.1.8
07/07/2003 20:41:25 - UPnP / NAT-PMP support [ON]
07/07/2003 20:41:25 - Options were saved successfully.
07/07/2003 15:00:31 - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: 6881
07/07/2003 15:00:31 - Reason: Tula.The.Revolt.2013.DVDRip.x264-EXViD[rarbg] fast resume rejected: missing or invalid 'file sizes' entry
07/07/2003 15:00:31 - Fast resume data was rejected for torrent Tula.The.Revolt.2013.DVDRip.x264-EXViD[rarbg], checking again...
07/07/2003 15:00:31 - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: 0
07/07/2003 15:00:31 - External IP: 197.205.73.19
07/07/2003 15:00:31 - qBittorrent is successfully listening on interface 0.0.0.0 port: TCP/6881
07/07/2003 15:00:31 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\bd67ce98ab24eb703897ef7324c9e81f4d0a712e.torrent' resumed. (fast resume)
07/07/2003 15:00:31 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\6c22301adcaeed74d1f89cc1eb2d3538102e2dbc.torrent' resumed. (fast resume)
07/07/2003 15:00:31 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\3c85f73e41884ac9d075c11c82995bfb9fe4c08c.torrent' resumed. (fast resume)
07/07/2003 15:00:31 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\c4d3c54f0e792147bcd9e8cbcbd637860984918b.torrent' resumed. (fast resume)
07/07/2003 15:00:31 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\0d24cb54f09bbc1d84d5edb2858b9911abab9241.torrent' resumed. (fast resume)
07/07/2003 15:00:31 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\af6fa7b477cd92530bfbbfb32f3eb8265425f734.torrent' resumed. (fast resume)
07/07/2003 15:00:31 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\a1dc6dcabb69db4a951979eb0df894f9e8a159ad.torrent' resumed. (fast resume)
07/07/2003 15:00:30 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\e1e9bcf1da2e21fba8c2bb865f9201f3f71e4723.torrent' resumed. (fast resume)
07/07/2003 15:00:30 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\7e5fdef411810a259bb98c5df2c0e4db2ea9a5a4.torrent' resumed. (fast resume)
07/07/2003 15:00:30 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\5cd7a3aa1b1c0307fec9527461e5c48705ce7adc.torrent' resumed. (fast resume)
07/07/2003 15:00:30 - 'C:\Documents and Settings\Coldlm\Local Settings\Application Data\qBittorrent\BT_backup\1905d2bac7267beb58235171dda8bef871b9971f.torrent' resumed. (fast resume)
07/07/2003 15:00:30 - Options were saved successfully.
07/07/2003 15:00:30 - Embedded Tracker [OFF]
07/07/2003 15:00:30 - Encryption support [ON]
07/07/2003 15:00:30 - Local Peer Discovery support [ON]
07/07/2003 15:00:30 - PeX support [ON]
07/07/2003 15:00:30 - DHT support [ON], port: UDP/6881
07/07/2003 15:00:30 - Anonymous mode [OFF]
07/07/2003 15:00:30 - HTTP user agent is qBittorrent v3.1.8
07/07/2003 15:00:30 - UPnP / NAT-PMP support [ON]
07/07/2003 15:00:29 - qBittorrent is trying to listen on any interface port: TCP/6881
07/07/2003 15:00:29 - Peer ID: -qB3180-
this the only thing i can see, no blocked ips, also ignor the times and dates
The log has tabs on the right. Click "blocked ips"
Also latest is v3.1.9
coldlm
Post by coldlm »
Yeah i just that tab, here is what i saw there
also i will update and see if that fixes the problem!
08/07/2003 15:16:57 - 2.218.28.165 was blocked
08/07/2003 15:14:02 - 77.231.44.244 was blocked
08/07/2003 15:13:08 - 79.176.57.19 was blocked
08/07/2003 15:12:14 - 121.54.54.131 was blocked
08/07/2003 15:12:09 - 77.231.44.244 was blocked
08/07/2003 15:09:02 - 79.176.57.19 was blocked
08/07/2003 15:08:51 - 121.54.54.131 was blocked
08/07/2003 15:08:07 - 177.17.77.44 was blocked
08/07/2003 15:08:06 - 5.54.154.27 was blocked
08/07/2003 15:08:06 - 79.176.57.19 was blocked
08/07/2003 15:08:05 - 5.54.154.27 was blocked
08/07/2003 15:08:05 - 2.218.28.165 was blocked
08/07/2003 15:07:58 - 87.212.8.250 was blocked
08/07/2003 15:07:58 - 77.49.125.253 was blocked
08/07/2003 15:07:58 - 89.137.224.100 was blocked
08/07/2003 15:07:58 - 186.176.10.64 was blocked
08/07/2003 15:07:58 - 103.24.190.72 was blocked
08/07/2003 15:07:58 - 144.82.191.250 was blocked
08/07/2003 15:07:58 - 176.225.104.254 was blocked
08/07/2003 15:07:58 - 80.178.137.3 was blocked
08/07/2003 15:07:58 - 84.250.51.241 was blocked
08/07/2003 15:07:58 - 76.30.203.237 was blocked
08/07/2003 15:07:58 - 67.177.127.101 was blocked
08/07/2003 15:07:58 - 84.194.85.40 was blocked
08/07/2003 15:07:58 - 78.251.147.106 was blocked
08/07/2003 15:07:58 - 94.52.24.184 was blocked
08/07/2003 15:07:58 - 46.140.139.66 was blocked
08/07/2003 15:07:58 - 84.198.179.148 was blocked
08/07/2003 15:07:58 - 197.148.36.142 was blocked
08/07/2003 15:07:58 - 188.27.66.185 was blocked
08/07/2003 15:07:58 - 41.249.183.146 was blocked
08/07/2003 15:07:58 - 108.180.180.130 was blocked
08/07/2003 15:07:58 - 98.121.166.247 was blocked
08/07/2003 15:07:58 - 223.206.250.35 was blocked
08/07/2003 15:07:58 - 14.99.198.94 was blocked
08/07/2003 15:07:58 - 2.84.139.215 was blocked
08/07/2003 15:07:58 - 94.250.175.14 was blocked
08/07/2003 15:07:58 - 179.126.13.26 was blocked
08/07/2003 15:07:58 - 190.3.154.150 was blocked
08/07/2003 15:07:58 - 89.70.14.226 was blocked
08/07/2003 15:07:58 - 147.251.170.205 was blocked
08/07/2003 15:07:58 - 109.201.154.183 was blocked
08/07/2003 15:07:57 - 5.54.154.27 was blocked
08/07/2003 15:04:09 - 121.54.54.131 was blocked
08/07/2003 15:04:03 - 190.105.123.89 was banned
08/07/2003 15:04:03 - 177.157.152.179 was banned
08/07/2003 15:04:03 - 83.84.224.247 was banned
08/07/2003 14:53:11 - 5.54.154.27 was blocked
08/07/2003 14:53:11 - 2.218.28.165 was blocked
08/07/2003 14:53:10 - 5.54.154.27 was blocked
08/07/2003 14:53:10 - 79.176.57.19 was blocked
08/07/2003 14:53:09 - 5.54.154.27 was blocked
08/07/2003 14:53:09 - 2.218.28.165 was blocked
08/07/2003 14:53:02 - 124.186.108.48 was blocked
08/07/2003 14:53:02 - 190.3.154.150 was blocked
08/07/2003 14:53:02 - 72.183.35.226 was blocked
08/07/2003 14:53:02 - 72.252.113.84 was blocked
08/07/2003 14:53:02 - 147.251.170.205 was blocked
08/07/2003 14:53:02 - 109.201.154.183 was blocked
08/07/2003 14:53:02 - 82.74.221.214 was blocked
08/07/2003 14:53:02 - 77.28.253.39 was blocked
08/07/2003 14:53:02 - 193.91.172.178 was blocked
08/07/2003 14:53:02 - 197.234.245.80 was blocked
08/07/2003 14:53:02 - 178.72.229.33 was blocked
08/07/2003 14:53:02 - 86.58.63.251 was blocked
08/07/2003 14:53:02 - 92.68.143.18 was blocked
08/07/2003 14:53:02 - 177.205.32.93 was blocked
08/07/2003 14:53:02 - 94.59.125.235 was blocked
08/07/2003 14:53:02 - 200.138.62.31 was blocked
08/07/2003 14:53:02 - 79.177.50.131 was blocked
08/07/2003 14:53:02 - 79.101.217.10 was blocked
08/07/2003 14:53:02 - 201.214.114.145 was blocked
08/07/2003 14:53:02 - 84.73.148.235 was blocked
08/07/2003 14:53:02 - 189.71.189.26 was blocked
08/07/2003 14:53:02 - 117.104.128.221 was blocked
08/07/2003 14:53:02 - 2.218.28.165 was blocked
08/07/2003 14:49:24 - 2.218.28.165 was blocked
08/07/2003 14:48:46 - 81.94.199.172 was banned
08/07/2003 14:48:46 - 189.46.153.165 was banned
08/07/2003 14:48:46 - 200.9.237.163 was banned
08/07/2003 14:48:46 - 46.246.209.47 was banned
08/07/2003 14:48:46 - 172.218.27.216 was banned
08/07/2003 14:42:09 - 201.78.68.196 was blocked
08/07/2003 14:38:11 - 178.233.165.209 was blocked
08/07/2003 14:38:11 - 79.176.57.19 was blocked
08/07/2003 14:38:11 - 2.218.28.165 was blocked
08/07/2003 14:38:09 - 142.166.205.174 was blocked
08/07/2003 14:38:09 - 177.17.77.44 was blocked
08/07/2003 14:38:09 - 2.218.28.165 was blocked
08/07/2003 14:38:06 - 2.218.28.165 was blocked
08/07/2003 14:38:06 - 49.145.53.99 was blocked
08/07/2003 14:38:06 - 117.104.128.221 was blocked
08/07/2003 14:38:06 - 98.231.105.95 was blocked
08/07/2003 14:38:06 - 144.82.191.250 was blocked
08/07/2003 14:38:06 - 176.225.104.254 was blocked
08/07/2003 14:38:06 - 108.180.180.130 was blocked
08/07/2003 14:38:06 - 88.195.14.14 was blocked
08/07/2003 14:38:06 - 124.186.108.48 was blocked
08/07/2003 14:38:06 - 96.49.32.50 was blocked
08/07/2003 14:38:06 - 141.237.145.173 was blocked
08/07/2003 14:38:06 - 14.99.198.94 was blocked
08/07/2003 14:38:06 - 177.205.32.93 was blocked
08/07/2003 14:38:06 - 77.28.253.39 was blocked
08/07/2003 14:38:06 - 82.74.221.214 was blocked
08/07/2003 14:38:06 - 98.121.166.247 was blocked
08/07/2003 14:38:06 - 94.52.24.184 was blocked
08/07/2003 14:38:06 - 78.251.147.106 was blocked
08/07/2003 14:38:06 - 59.101.24.94 was blocked
08/07/2003 14:38:06 - 188.27.66.185 was blocked
08/07/2003 14:38:06 - 223.206.250.35 was blocked
08/07/2003 14:38:06 - 187.126.89.208 was blocked
08/07/2003 14:38:06 - 192.87.23.71 was blocked
08/07/2003 14:38:06 - 189.63.138.85 was blocked
08/07/2003 14:38:06 - 179.126.13.26 was blocked
08/07/2003 14:38:06 - 5.245.179.19 was blocked
08/07/2003 14:38:06 - 176.205.195.76 was blocked
08/07/2003 14:37:59 - 79.176.57.19 was blocked
08/07/2003 14:35:59 - 2.218.28.165 was blocked
08/07/2003 14:31:23 - 218.186.228.70 was blocked
08/07/2003 14:23:16 - 79.176.57.19 was blocked
08/07/2003 14:23:16 - 2.218.28.165 was blocked
08/07/2003 14:23:16 - 110.174.195.207 was blocked
08/07/2003 14:23:15 - 79.176.57.19 was blocked
08/07/2003 14:23:15 - 142.166.205.174 was blocked
08/07/2003 14:23:14 - 2.218.28.165 was blocked
08/07/2003 14:23:14 - 87.109.70.239 was blocked
08/07/2003 14:23:13 - 79.176.57.19 was blocked
08/07/2003 14:23:10 - 144.122.141.66 was blocked
08/07/2003 14:23:10 - 192.87.23.71 was blocked
08/07/2003 14:23:10 - 85.102.76.168 was blocked
08/07/2003 14:23:10 - 188.27.66.185 was blocked
08/07/2003 14:23:10 - 184.75.208.122 was blocked
08/07/2003 14:23:10 - 72.252.113.84 was blocked
08/07/2003 14:23:10 - 66.66.1.204 was blocked
08/07/2003 14:23:10 - 109.201.154.183 was blocked
08/07/2003 14:23:10 - 99.103.205.37 was blocked
08/07/2003 14:23:10 - 85.92.224.254 was blocked
08/07/2003 14:23:10 - 107.203.94.60 was blocked
08/07/2003 14:23:10 - 94.214.1.46 was blocked
08/07/2003 14:23:10 - 103.24.190.72 was blocked
08/07/2003 14:23:10 - 96.53.10.62 was blocked
08/07/2003 14:23:10 - 94.98.121.6 was blocked
08/07/2003 14:23:10 - 86.58.63.251 was blocked
08/07/2003 14:23:10 - 142.134.151.143 was blocked
08/07/2003 14:23:10 - 5.102.241.78 was blocked
08/07/2003 14:23:10 - 178.221.25.78 was blocked
08/07/2003 14:23:10 - 86.132.52.87 was blocked
08/07/2003 14:23:10 - 94.59.125.235 was blocked
08/07/2003 14:23:10 - 200.138.62.31 was blocked
08/07/2003 14:23:10 - 178.61.3.153 was blocked
08/07/2003 14:23:10 - 84.194.85.40 was blocked
08/07/2003 14:23:10 - 121.54.32.108 was blocked
08/07/2003 14:23:10 - 2.218.28.165 was blocked
08/07/2003 14:20:20 - 2.218.28.165 was blocked
08/07/2003 14:13:00 - 107.131.118.34 was blocked
08/07/2003 14:10:00 - 188.27.119.180 was blocked
08/07/2003 14:10:00 - 178.233.165.209 was blocked
08/07/2003 14:08:23 - 2.218.28.165 was blocked
08/07/2003 14:08:23 - 79.176.57.19 was blocked
08/07/2003 14:08:21 - 2.218.28.165 was blocked
08/07/2003 14:08:15 - 187.126.89.208 was blocked
08/07/2003 14:08:14 - 176.225.104.254 was blocked
08/07/2003 14:08:14 - 24.89.254.255 was blocked
08/07/2003 14:08:14 - 122.167.204.229 was blocked
08/07/2003 14:08:14 - 85.102.76.168 was blocked
08/07/2003 14:08:14 - 188.27.66.185 was blocked
08/07/2003 14:08:14 - 184.75.208.122 was blocked
08/07/2003 14:08:14 - 213.148.228.206 was blocked
08/07/2003 14:08:14 - 109.201.154.183 was blocked
08/07/2003 14:08:14 - 109.122.85.66 was blocked
08/07/2003 14:08:14 - 85.92.224.254 was blocked
08/07/2003 14:08:14 - 186.136.140.222 was blocked
08/07/2003 14:08:14 - 103.24.190.72 was blocked
08/07/2003 14:08:14 - 96.53.10.62 was blocked
08/07/2003 14:08:14 - 107.131.118.34 was blocked
08/07/2003 14:08:14 - 94.59.161.231 was blocked
08/07/2003 14:08:14 - 86.58.63.251 was blocked
08/07/2003 14:08:14 - 142.134.151.143 was blocked
08/07/2003 14:08:14 - 179.159.86.143 was blocked
08/07/2003 14:08:14 - 89.201.229.185 was blocked
08/07/2003 14:08:14 - 178.221.25.78 was blocked
08/07/2003 14:08:14 - 86.132.52.87 was blocked
08/07/2003 14:08:14 - 59.148.142.128 was blocked
08/07/2003 14:08:14 - 200.138.62.31 was blocked
08/07/2003 14:08:14 - 178.61.3.153 was blocked
08/07/2003 14:08:14 - 84.194.85.40 was blocked
08/07/2003 14:08:14 - 106.69.174.54 was blocked
08/07/2003 14:03:56 - 186.106.117.82 was blocked
08/07/2003 14:03:36 - 110.174.195.207 was blocked
08/07/2003 14:02:21 - 121.54.54.131 was blocked
08/07/2003 14:02:05 - 190.3.154.150 was blocked
08/07/2003 14:02:04 - 178.233.165.209 was blocked
08/07/2003 14:01:29 - 121.54.54.131 was blocked
08/07/2003 14:00:04 - 178.233.165.209 was blocked
08/07/2003 13:59:45 - 2.218.28.165 was blocked
08/07/2003 13:56:07 - 2.218.28.165 was blocked
08/07/2003 13:56:04 - 178.233.165.209 was blocked
08/07/2003 13:53:36 - 207.161.23.46 was blocked
08/07/2003 13:53:22 - 2.218.28.165 was blocked
08/07/2003 13:53:20 - 5.14.14.159 was blocked
08/07/2003 13:53:19 - 2.218.28.165 was blocked
08/07/2003 13:53:19 - 91.202.242.228 was blocked
08/07/2003 13:53:19 - 122.167.122.148 was blocked
08/07/2003 13:53:19 - 2.51.45.101 was blocked
08/07/2003 13:53:19 - 14.200.104.126 was blocked
08/07/2003 13:53:19 - 122.167.204.229 was blocked
08/07/2003 13:53:19 - 85.102.76.168 was blocked
08/07/2003 13:53:19 - 85.93.203.41 was blocked
08/07/2003 13:53:19 - 184.75.208.122 was blocked
08/07/2003 13:53:19 - 213.148.228.206 was blocked
08/07/2003 13:53:19 - 109.201.154.183 was blocked
08/07/2003 13:53:19 - 109.122.85.66 was blocked
08/07/2003 13:53:19 - 186.136.140.222 was blocked
08/07/2003 13:53:19 - 103.24.190.72 was blocked
08/07/2003 13:53:19 - 96.53.10.62 was blocked
08/07/2003 13:53:19 - 107.131.118.34 was blocked
08/07/2003 13:53:19 - 94.59.161.231 was blocked
08/07/2003 13:53:19 - 85.96.48.221 was blocked
08/07/2003 13:53:19 - 75.144.18.41 was blocked
08/07/2003 13:53:19 - 179.126.13.26 was blocked
08/07/2003 13:53:19 - 179.159.86.143 was blocked
08/07/2003 13:53:19 - 89.201.229.185 was blocked
08/07/2003 13:53:19 - 59.148.142.128 was blocked
08/07/2003 13:52:33 - 121.54.54.131 was blocked
08/07/2003 13:52:02 - 178.233.165.209 was blocked
08/07/2003 13:50:24 - 123.243.225.102 was banned
08/07/2003 13:50:24 - 82.234.71.64 was banned
08/07/2003 13:49:50 - 121.54.54.131 was blocked
08/07/2003 13:49:31 - 121.54.54.131 was blocked
08/07/2003 13:49:02 - 122.167.204.229 was blocked
08/07/2003 13:44:45 - 110.174.195.207 was blocked
08/07/2003 13:44:45 - 2.218.28.165 was blocked
08/07/2003 13:44:13 - 121.54.54.131 was blocked
08/07/2003 13:44:13 - 190.92.46.194 was blocked
08/07/2003 13:43:37 - 190.92.46.194 was blocked
08/07/2003 13:43:20 - 190.92.46.194 was blocked
08/07/2003 13:42:43 - 190.92.46.194 was blocked
08/07/2003 13:42:14 - 190.92.46.194 was blocked
08/07/2003 13:41:53 - 190.92.46.194 was blocked
08/07/2003 13:41:44 - 190.92.46.194 was blocked
08/07/2003 13:41:40 - 121.54.54.131 was blocked
08/07/2003 13:40:44 - 190.92.46.194 was blocked
08/07/2003 13:39:57 - 190.92.46.194 was blocked
08/07/2003 13:39:57 - 122.167.204.229 was blocked
08/07/2003 13:39:46 - 190.92.46.194 was blocked
08/07/2003 13:39:38 - 190.92.46.194 was blocked
08/07/2003 13:39:27 - 27.122.12.75 was banned
08/07/2003 13:39:27 - 84.108.106.102 was banned
08/07/2003 13:39:27 - 197.226.147.3 was banned
08/07/2003 13:39:27 - 86.27.176.188 was banned
08/07/2003 13:39:27 - 108.180.221.143 was banned
08/07/2003 13:39:27 - 108.172.219.93 was banned
08/07/2003 13:39:27 - 79.36.218.246 was banned
08/07/2003 13:39:27 - 97.94.182.5 was banned
08/07/2003 13:39:23 - 178.233.165.209 was blocked
08/07/2003 13:39:02 - 190.92.46.194 was blocked
08/07/2003 13:38:29 - 193.219.163.162 was blocked
08/07/2003 13:38:29 - 79.176.57.19 was blocked
08/07/2003 13:38:29 - 190.92.46.194 was blocked
08/07/2003 13:38:27 - 2.218.28.165 was blocked
08/07/2003 13:38:23 - 122.167.122.148 was blocked
08/07/2003 13:38:23 - 197.234.245.80 was blocked
08/07/2003 13:38:23 - 178.235.50.125 was blocked
08/07/2003 13:38:23 - 86.140.223.99 was blocked
08/07/2003 13:38:23 - 179.159.86.143 was blocked
08/07/2003 13:38:23 - 94.59.161.231 was blocked
08/07/2003 13:38:23 - 109.122.85.66 was blocked
08/07/2003 13:38:23 - 184.75.208.122 was blocked
08/07/2003 13:38:23 - 2.51.45.101 was blocked
08/07/2003 13:38:23 - 14.200.104.126 was blocked
08/07/2003 13:38:23 - 122.167.204.229 was blocked
08/07/2003 13:38:23 - 85.102.76.168 was blocked
08/07/2003 13:38:23 - 85.93.203.41 was blocked
08/07/2003 13:38:23 - 46.116.184.219 was blocked
08/07/2003 13:38:23 - 2.84.128.173 was blocked
08/07/2003 13:38:23 - 109.201.154.183 was blocked
08/07/2003 13:38:23 - 5.245.179.19 was blocked
08/07/2003 13:38:23 - 103.24.190.72 was blocked
08/07/2003 13:38:23 - 96.53.10.62 was blocked
08/07/2003 13:38:23 - 107.131.118.34 was blocked
08/07/2003 13:38:23 - 172.2.100.112 was blocked
08/07/2003 13:38:23 - 83.177.198.47 was blocked
08/07/2003 13:38:23 - 85.96.48.221 was blocked
08/07/2003 13:38:23 - 75.144.18.41 was blocked
08/07/2003 13:37:22 - 121.54.54.131 was blocked
08/07/2003 13:37:11 - 190.92.46.194 was blocked
08/07/2003 13:36:46 - 96.53.10.62 was blocked
08/07/2003 13:35:54 - 190.92.46.194 was blocked
08/07/2003 13:35:29 - 190.92.46.194 was blocked
08/07/2003 13:35:12 - 190.92.46.194 was blocked
08/07/2003 13:34:53 - 190.92.46.194 was blocked
08/07/2003 13:34:48 - 121.54.54.131 was blocked
08/07/2003 13:34:39 - 121.54.54.131 was blocked
08/07/2003 13:33:52 - 187.126.89.208 was blocked
08/07/2003 13:33:24 - 190.92.46.194 was blocked
08/07/2003 13:32:42 - 190.92.46.194 was blocked
08/07/2003 13:32:37 - 121.54.54.131 was blocked
08/07/2003 13:32:18 - 190.92.46.194 was blocked
08/07/2003 13:31:09 - 190.92.46.194 was blocked
08/07/2003 13:30:39 - 121.54.54.131 was blocked
08/07/2003 13:30:14 - 190.92.46.194 was blocked
08/07/2003 13:29:50 - 190.92.46.194 was blocked
08/07/2003 13:29:44 - 190.92.46.194 was blocked
08/07/2003 13:29:42 - 121.54.54.131 was blocked
08/07/2003 13:28:48 - 190.92.46.194 was blocked
08/07/2003 13:28:45 - 190.92.46.194 was blocked
08/07/2003 13:28:28 - 121.54.54.131 was blocked
08/07/2003 13:28:06 - 190.92.46.194 was blocked
08/07/2003 13:27:54 - 190.92.46.194 was blocked
08/07/2003 13:26:57 - 190.92.46.194 was blocked
08/07/2003 13:25:23 - 190.92.46.194 was blocked
08/07/2003 13:24:19 - 190.92.46.194 was blocked
08/07/2003 13:23:39 - 190.92.46.194 was blocked
08/07/2003 13:23:37 - 190.92.46.194 was blocked
08/07/2003 13:23:33 - 2.218.28.165 was blocked
08/07/2003 13:23:32 - 190.92.46.194 was blocked
08/07/2003 13:23:31 - 110.174.195.207 was blocked
08/07/2003 13:23:31 - 178.233.165.209 was blocked
08/07/2003 13:23:31 - 2.218.28.165 was blocked
08/07/2003 13:23:28 - 2.218.28.165 was blocked
08/07/2003 13:23:27 - 186.176.10.64 was blocked
08/07/2003 13:23:27 - 185.18.63.239 was blocked
08/07/2003 13:23:27 - 130.43.88.126 was blocked
08/07/2003 13:23:27 - 62.195.208.154 was blocked
08/07/2003 13:23:27 - 46.140.139.66 was blocked
08/07/2003 13:23:27 - 87.109.70.239 was blocked
08/07/2003 13:23:27 - 141.237.145.173 was blocked
08/07/2003 13:23:27 - 122.56.60.1 was blocked
08/07/2003 13:23:27 - 181.166.211.219 was blocked
08/07/2003 13:23:27 - 121.54.54.131 was blocked
08/07/2003 13:23:27 - 83.5.172.80 was blocked
08/07/2003 13:23:27 - 82.74.221.214 was blocked
08/07/2003 13:23:27 - 117.104.128.221 was blocked
08/07/2003 13:23:27 - 115.64.99.80 was blocked
08/07/2003 13:23:27 - 84.85.138.155 was blocked
08/07/2003 13:23:27 - 77.28.251.193 was blocked
08/07/2003 13:23:27 - 31.15.167.81 was blocked
08/07/2003 13:23:27 - 72.183.35.226 was blocked
08/07/2003 13:23:27 - 177.206.171.31 was blocked
08/07/2003 13:23:27 - 89.201.229.185 was blocked
08/07/2003 13:23:27 - 178.235.50.125 was blocked
08/07/2003 13:23:27 - 86.140.223.99 was blocked
08/07/2003 13:23:27 - 184.161.103.34 was blocked
08/07/2003 13:23:27 - 179.126.13.26 was blocked
08/07/2003 13:23:27 - 187.126.89.208 was blocked
08/07/2003 13:23:27 - 46.116.184.219 was blocked
08/07/2003 13:23:27 - 2.84.128.173 was blocked
08/07/2003 13:23:27 - 189.71.173.137 was blocked
08/07/2003 13:22:53 - 190.92.46.194 was blocked
08/07/2003 13:22:49 - 190.92.46.194 was blocked
08/07/2003 13:22:40 - 190.92.46.194 was blocked
08/07/2003 13:22:37 - 124.148.80.125 was blocked
08/07/2003 13:22:25 - 190.92.46.194 was blocked
08/07/2003 13:22:15 - 190.92.46.194 was blocked
08/07/2003 13:21:59 - 190.92.46.194 was blocked
08/07/2003 13:21:38 - 190.92.46.194 was blocked
08/07/2003 13:21:07 - 190.92.46.194 was blocked
08/07/2003 13:20:32 - 190.92.46.194 was blocked
08/07/2003 13:19:37 - 190.92.46.194 was blocked
08/07/2003 13:19:35 - 190.92.46.194 was blocked
08/07/2003 13:19:32 - 190.92.46.194 was blocked
08/07/2003 13:19:28 - 121.54.54.131 was blocked
08/07/2003 13:19:21 - 190.92.46.194 was blocked
08/07/2003 13:19:02 - 190.92.46.194 was blocked
08/07/2003 13:18:41 - 2.218.28.165 was blocked
08/07/2003 13:18:37 - 190.92.46.194 was blocked
08/07/2003 13:17:57 - 190.92.46.194 was blocked
08/07/2003 13:17:47 - 190.92.46.194 was blocked
08/07/2003 13:17:11 - 110.174.195.207 was blocked
08/07/2003 13:17:09 - 190.92.46.194 was blocked
08/07/2003 13:16:07 - 190.92.46.194 was blocked
08/07/2003 13:16:06 - 190.92.46.194 was blocked
08/07/2003 13:15:50 - 190.92.46.194 was blocked
08/07/2003 13:15:15 - 190.92.46.194 was blocked
08/07/2003 13:14:21 - 190.92.46.194 was blocked
08/07/2003 13:13:25 - 190.92.46.194 was blocked
08/07/2003 13:12:35 - 190.92.46.194 was blocked
08/07/2003 13:11:37 - 190.92.46.194 was blocked
08/07/2003 13:11:29 - 190.92.46.194 was blocked
08/07/2003 13:11:20 - 88.195.14.14 was blocked
08/07/2003 13:10:28 - 121.54.54.131 was blocked
08/07/2003 13:10:21 - 190.92.46.194 was blocked
08/07/2003 13:10:09 - 190.92.46.194 was blocked
08/07/2003 13:10:00 - 94.209.231.43 was banned
08/07/2003 13:10:00 - 31.47.13.177 was banned
08/07/2003 13:10:00 - 77.165.248.81 was banned
08/07/2003 13:10:00 - 213.57.223.242 was banned
08/07/2003 13:10:00 - 79.129.43.254 was banned
08/07/2003 13:10:00 - 50.64.60.23 was banned
08/07/2003 13:10:00 - 87.86.136.130 was banned
08/07/2003 13:10:00 - 195.117.209.62 was banned
08/07/2003 13:09:56 - 190.92.46.194 was blocked
08/07/2003 13:09:17 - 190.92.46.194 was blocked
08/07/2003 13:08:37 - 190.92.46.194 was blocked
08/07/2003 13:08:37 - 2.218.28.165 was blocked
08/07/2003 13:08:36 - 2.218.28.165 was blocked
08/07/2003 13:08:35 - 2.218.28.165 was blocked
08/07/2003 13:08:34 - 190.92.46.194 was blocked
08/07/2003 13:08:32 - 122.167.122.148 was blocked
08/07/2003 13:08:31 - 77.28.251.193 was blocked
08/07/2003 13:08:31 - 46.162.226.98 was blocked
08/07/2003 13:08:31 - 187.253.219.115 was blocked
08/07/2003 13:08:31 - 177.206.171.31 was blocked
08/07/2003 13:08:31 - 89.201.229.185 was blocked
08/07/2003 13:08:31 - 178.235.50.125 was blocked
08/07/2003 13:08:31 - 78.104.182.174 was blocked
08/07/2003 13:08:31 - 46.116.184.219 was blocked
08/07/2003 13:08:31 - 75.144.18.41 was blocked
08/07/2003 13:08:31 - 187.126.89.208 was blocked
08/07/2003 13:08:31 - 80.230.20.10 was blocked
08/07/2003 13:08:31 - 178.72.229.33 was blocked
08/07/2003 13:08:31 - 189.71.173.137 was blocked
08/07/2003 13:08:31 - 5.245.179.19 was blocked
08/07/2003 13:08:31 - 186.45.200.81 was blocked
08/07/2003 13:08:31 - 91.73.150.21 was blocked
08/07/2003 13:08:31 - 179.126.13.26 was blocked
08/07/2003 13:08:31 - 88.166.13.219 was blocked
08/07/2003 13:08:31 - 96.53.10.62 was blocked
08/07/2003 13:08:31 - 80.7.77.198 was blocked
08/07/2003 13:08:31 - 172.2.100.112 was blocked
08/07/2003 13:08:31 - 83.177.198.47 was blocked
08/07/2003 13:08:31 - 200.138.62.31 was blocked
08/07/2003 13:08:31 - 190.3.154.150 was blocked
08/07/2003 13:08:31 - 186.105.105.251 was blocked
08/07/2003 13:08:31 - 190.16.250.118 was blocked
08/07/2003 13:08:31 - 186.176.10.64 was blocked
08/07/2003 13:08:31 - 185.18.63.239 was blocked
08/07/2003 13:08:31 - 130.43.88.126 was blocked
08/07/2003 13:08:31 - 83.83.112.42 was blocked
08/07/2003 13:08:31 - 59.181.129.181 was blocked
08/07/2003 13:08:31 - 87.109.70.239 was blocked
08/07/2003 13:08:31 - 109.79.49.91 was blocked
08/07/2003 13:08:31 - 122.56.60.1 was blocked
08/07/2003 13:08:31 - 24.89.254.255 was blocked
08/07/2003 13:08:19 - 190.92.46.194 was blocked
08/07/2003 13:07:50 - 190.92.46.194 was blocked
08/07/2003 13:07:45 - 190.92.46.194 was blocked
08/07/2003 13:07:05 - 190.92.46.194 was blocked
08/07/2003 13:06:14 - 190.92.46.194 was blocked
08/07/2003 13:06:10 - 190.92.46.194 was blocked
08/07/2003 13:05:58 - 190.92.46.194 was blocked
08/07/2003 13:05:50 - 190.92.46.194 was blocked
08/07/2003 13:04:51 - 190.92.46.194 was blocked
08/07/2003 13:04:51 - 121.54.54.131 was blocked
08/07/2003 13:03:13 - 78.251.147.106 was blocked
08/07/2003 13:03:09 - 190.92.46.194 was blocked
08/07/2003 13:02:47 - 190.92.46.194 was blocked
08/07/2003 13:02:45 - 190.92.46.194 was blocked
08/07/2003 13:00:29 - 190.92.46.194 was blocked
08/07/2003 12:59:54 - 178.233.165.209 was blocked
08/07/2003 12:59:46 - 190.92.46.194 was blocked
08/07/2003 12:59:45 - 190.92.46.194 was blocked
08/07/2003 12:59:37 - 121.54.54.131 was blocked
08/07/2003 12:59:37 - 190.92.46.194 was blocked
08/07/2003 12:59:36 - 121.54.54.131 was blocked
08/07/2003 12:59:21 - 190.92.46.194 was blocked
08/07/2003 12:59:07 - 190.92.46.194 was blocked
08/07/2003 12:58:54 - 190.92.46.194 was blocked
08/07/2003 12:58:49 - 190.92.46.194 was blocked
08/07/2003 12:57:44 - 190.92.46.194 was blocked
08/07/2003 12:57:37 - 190.92.46.194 was blocked
08/07/2003 12:57:30 - 190.92.46.194 was blocked
08/07/2003 12:57:19 - 122.167.204.229 was blocked
08/07/2003 12:56:42 - 190.92.46.194 was blocked
08/07/2003 12:56:31 - 190.92.46.194 was blocked
08/07/2003 12:56:21 - 190.92.46.194 was blocked
08/07/2003 12:55:26 - 190.92.46.194 was blocked
08/07/2003 12:54:59 - 190.92.46.194 was blocked
08/07/2003 12:54:15 - 124.148.80.125 was blocked
08/07/2003 12:54:12 - 142.166.205.174 was blocked
08/07/2003 12:53:50 - 190.92.46.194 was blocked
08/07/2003 12:53:42 - 87.109.70.239 was blocked
08/07/2003 12:53:40 - 2.218.28.165 was blocked
08/07/2003 12:53:38 - 190.92.46.194 was blocked
08/07/2003 12:53:35 - 87.109.70.239 was blocked
08/07/2003 12:53:35 - 83.177.198.47 was blocked
08/07/2003 12:53:35 - 91.73.150.21 was blocked
08/07/2003 12:53:35 - 213.55.103.182 was blocked
08/07/2003 12:53:35 - 109.254.49.37 was blocked
08/07/2003 12:53:35 - 211.198.139.8 was blocked
08/07/2003 12:53:35 - 75.144.18.41 was blocked
08/07/2003 12:53:35 - 187.126.89.208 was blocked
08/07/2003 12:53:35 - 80.230.20.10 was blocked
08/07/2003 12:53:35 - 178.72.229.33 was blocked
08/07/2003 12:53:35 - 142.177.83.114 was blocked
08/07/2003 12:53:35 - 193.91.172.178 was blocked
08/07/2003 12:53:35 - 5.245.179.19 was blocked
08/07/2003 12:53:35 - 186.45.200.81 was blocked
08/07/2003 12:53:35 - 81.203.192.15 was blocked
08/07/2003 12:53:35 - 179.126.13.26 was blocked
08/07/2003 12:53:35 - 96.53.10.62 was blocked
08/07/2003 12:53:35 - 80.7.77.198 was blocked
08/07/2003 12:53:35 - 79.167.45.121 was blocked
08/07/2003 12:53:35 - 85.17.73.202 was blocked
08/07/2003 12:53:35 - 200.138.62.31 was blocked
08/07/2003 12:53:35 - 190.3.154.150 was blocked
08/07/2003 12:53:35 - 184.75.214.194 was blocked
08/07/2003 12:53:35 - 186.105.105.251 was blocked
08/07/2003 12:53:35 - 213.233.149.26 was blocked
08/07/2003 12:53:35 - 186.176.10.64 was blocked
08/07/2003 12:53:35 - 95.252.177.192 was blocked
08/07/2003 12:53:35 - 177.141.250.38 was blocked
08/07/2003 12:53:35 - 83.83.112.42 was blocked
08/07/2003 12:53:35 - 59.181.129.181 was blocked
08/07/2003 12:53:35 - 99.192.109.205 was blocked
08/07/2003 12:53:35 - 109.79.49.91 was blocked
08/07/2003 12:53:35 - 122.56.60.1 was blocked
08/07/2003 12:53:35 - 24.89.254.255 was blocked
08/07/2003 12:53:15 - 190.92.46.194 was blocked
08/07/2003 12:53:09 - 190.92.46.194 was blocked
08/07/2003 12:53:05 - 190.92.46.194 was blocked
08/07/2003 12:52:45 - 190.92.46.194 was blocked
08/07/2003 12:52:16 - 190.92.46.194 was blocked
08/07/2003 12:51:21 - 190.92.46.194 was blocked
08/07/2003 12:51:07 - 190.92.46.194 was blocked
08/07/2003 12:50:45 - 190.92.46.194 was blocked
08/07/2003 12:50:29 - 190.92.46.194 was blocked
08/07/2003 12:49:41 - 190.92.46.194 was blocked
08/07/2003 12:49:22 - 190.92.46.194 was blocked
08/07/2003 12:49:09 - 190.92.46.194 was blocked
08/07/2003 12:47:40 - 190.92.46.194 was blocked
08/07/2003 12:47:38 - 190.92.46.194 was blocked
08/07/2003 12:47:26 - 202.147.168.122 was blocked
08/07/2003 12:46:31 - 190.92.46.194 was blocked
08/07/2003 12:46:14 - 190.92.46.194 was blocked
08/07/2003 12:45:58 - 190.92.46.194 was blocked
08/07/2003 12:45:49 - 190.92.46.194 was blocked
08/07/2003 12:45:46 - 190.92.46.194 was blocked
08/07/2003 12:45:16 - 190.92.46.194 was blocked
08/07/2003 12:43:51 - 190.92.46.194 was blocked
08/07/2003 12:43:28 - 190.92.46.194 was blocked
08/07/2003 12:43:24 - 218.186.228.70 was blocked
08/07/2003 12:42:59 - 190.92.46.194 was blocked
08/07/2003 12:42:55 - 190.92.46.194 was blocked
08/07/2003 12:41:59 - 190.92.46.194 was blocked
08/07/2003 12:41:33 - 190.92.46.194 was blocked
08/07/2003 12:41:23 - 190.92.46.194 was blocked
08/07/2003 12:41:13 - 190.92.46.194 was blocked
08/07/2003 12:40:54 - 190.92.46.194 was blocked
08/07/2003 12:40:36 - 190.92.46.194 was blocked
08/07/2003 12:39:38 - 190.92.46.194 was blocked
08/07/2003 12:38:48 - 87.109.70.239 was blocked
08/07/2003 12:38:48 - 82.75.250.33 was blocked
08/07/2003 12:38:47 - 141.237.145.173 was blocked
08/07/2003 12:38:47 - 124.186.108.48 was blocked
08/07/2003 12:38:47 - 89.68.149.8 was blocked
08/07/2003 12:38:47 - 49.145.53.99 was blocked
08/07/2003 12:38:47 - 67.177.127.101 was blocked
08/07/2003 12:38:47 - 110.174.11.164 was blocked
08/07/2003 12:38:47 - 94.59.161.231 was blocked
08/07/2003 12:38:44 - 79.176.57.19 was blocked
08/07/2003 12:38:42 - 79.176.57.19 was blocked
08/07/2003 12:38:40 - 2.218.28.165 was blocked
08/07/2003 12:38:39 - 87.109.70.239 was blocked
08/07/2003 12:38:39 - 84.198.179.148 was blocked
08/07/2003 12:38:39 - 120.63.213.33 was blocked
08/07/2003 12:38:39 - 190.16.250.118 was blocked
08/07/2003 12:38:39 - 87.210.3.240 was blocked
08/07/2003 12:38:39 - 187.126.89.208 was blocked
08/07/2003 12:38:39 - 91.73.150.21 was blocked
08/07/2003 12:38:39 - 39.32.197.59 was blocked
08/07/2003 12:38:39 - 213.55.103.182 was blocked
08/07/2003 12:38:39 - 109.254.49.37 was blocked
08/07/2003 12:38:39 - 211.198.139.8 was blocked
08/07/2003 12:38:39 - 75.144.18.41 was blocked
08/07/2003 12:38:39 - 46.27.3.41 was blocked
08/07/2003 12:38:39 - 142.177.83.114 was blocked
08/07/2003 12:38:39 - 193.91.172.178 was blocked
08/07/2003 12:38:39 - 186.45.200.81 was blocked
08/07/2003 12:38:39 - 81.203.192.15 was blocked
08/07/2003 12:38:39 - 82.131.74.86 was blocked
08/07/2003 12:38:39 - 179.126.13.26 was blocked
08/07/2003 12:38:39 - 79.167.45.121 was blocked
08/07/2003 12:38:39 - 85.17.73.202 was blocked
08/07/2003 12:38:39 - 200.138.62.31 was blocked
08/07/2003 12:38:39 - 184.75.214.194 was blocked
08/07/2003 12:38:39 - 130.43.88.126 was blocked
08/07/2003 12:38:39 - 213.233.149.26 was blocked
08/07/2003 12:38:39 - 186.176.10.64 was blocked
08/07/2003 12:38:39 - 95.252.177.192 was blocked
08/07/2003 12:38:39 - 177.141.250.38 was blocked
08/07/2003 12:38:39 - 202.147.168.122 was blocked
08/07/2003 12:38:39 - 99.192.109.205 was blocked
08/07/2003 12:38:16 - 190.92.46.194 was blocked
08/07/2003 12:38:14 - 190.92.46.194 was blocked
08/07/2003 12:38:03 - 2.218.28.165 was blocked
08/07/2003 12:37:20 - 190.92.46.194 was blocked
08/07/2003 12:37:13 - 190.92.46.194 was blocked
08/07/2003 12:37:05 - 190.92.46.194 was blocked
08/07/2003 12:36:43 - 190.92.46.194 was blocked
08/07/2003 12:35:45 - 190.92.46.194 was blocked
08/07/2003 12:35:25 - 190.92.46.194 was blocked
08/07/2003 12:34:48 - 190.92.46.194 was blocked
08/07/2003 12:33:59 - 190.92.46.194 was blocked
08/07/2003 12:33:55 - 2.218.28.165 was blocked
08/07/2003 12:33:37 - 190.92.46.194 was blocked
08/07/2003 12:33:31 - 121.54.54.131 was blocked
08/07/2003 12:33:16 - 190.92.46.194 was blocked
08/07/2003 12:31:47 - 190.92.46.194 was blocked
08/07/2003 12:31:45 - 190.92.46.194 was blocked
08/07/2003 12:31:29 - 190.92.46.194 was blocked
08/07/2003 12:31:17 - 190.92.46.194 was blocked
08/07/2003 12:31:14 - 190.92.46.194 was blocked
08/07/2003 12:30:51 - 190.92.46.194 was blocked
08/07/2003 12:30:12 - 190.92.46.194 was blocked
08/07/2003 12:29:53 - 190.92.46.194 was blocked
08/07/2003 12:29:37 - 190.92.46.194 was blocked
08/07/2003 12:28:43 - 190.92.46.194 was blocked
08/07/2003 12:28:35 - 190.92.46.194 was blocked
08/07/2003 12:28:28 - 190.92.46.194 was blocked
08/07/2003 12:27:54 - 190.92.46.194 was blocked
08/07/2003 12:27:50 - 190.92.46.194 was blocked
08/07/2003 12:27:25 - 190.92.46.194 was blocked
08/07/2003 12:27:00 - 2.218.28.165 was blocked
08/07/2003 12:26:21 - 190.92.46.194 was blocked
08/07/2003 12:25:46 - 190.92.46.194 was blocked
08/07/2003 12:25:16 - 190.92.46.194 was blocked
08/07/2003 12:25:14 - 121.54.54.131 was blocked
08/07/2003 12:24:37 - 190.92.46.194 was blocked
08/07/2003 12:24:19 - 190.92.46.194 was blocked
08/07/2003 12:23:49 - 2.218.28.165 was blocked
08/07/2003 12:23:49 - 190.92.46.194 was blocked
08/07/2003 12:23:49 - 193.219.163.162 was blocked
08/07/2003 12:23:49 - 142.166.205.174 was blocked
08/07/2003 12:23:48 - 2.218.28.165 was blocked
08/07/2003 12:23:46 - 190.92.46.194 was blocked
08/07/2003 12:23:43 - 2.218.28.165 was blocked
08/07/2003 12:23:43 - 80.7.77.198 was blocked
08/07/2003 12:23:43 - 120.63.213.33 was blocked
08/07/2003 12:23:43 - 190.16.250.118 was blocked
08/07/2003 12:23:43 - 87.210.3.240 was blocked
08/07/2003 12:23:43 - 122.56.60.1 was blocked
08/07/2003 12:23:43 - 24.109.132.255 was blocked
08/07/2003 12:23:43 - 14.99.38.8 was blocked
08/07/2003 12:23:43 - 211.198.139.8 was blocked
08/07/2003 12:23:43 - 89.100.186.250 was blocked
08/07/2003 12:23:43 - 162.219.179.130 was blocked
08/07/2003 12:23:43 - 213.55.103.182 was blocked
08/07/2003 12:23:43 - 209.136.47.13 was blocked
08/07/2003 12:23:43 - 179.126.13.26 was blocked
08/07/2003 12:23:43 - 39.32.197.59 was blocked
08/07/2003 12:23:43 - 78.104.182.174 was blocked
08/07/2003 12:23:43 - 70.54.200.41 was blocked
08/07/2003 12:23:43 - 98.231.105.95 was blocked
08/07/2003 12:23:43 - 109.254.49.37 was blocked
08/07/2003 12:22:17 - 190.92.46.194 was blocked
08/07/2003 12:22:01 - 190.92.46.194 was blocked
08/07/2003 12:21:59 - 190.92.46.194 was blocked
08/07/2003 12:21:50 - 190.92.46.194 was blocked
08/07/2003 12:21:45 - 190.92.46.194 was blocked
08/07/2003 12:21:44 - 190.92.46.194 was blocked
08/07/2003 12:21:42 - 190.92.46.194 was blocked
08/07/2003 12:20:37 - 190.92.46.194 was blocked
08/07/2003 12:20:33 - 190.92.46.194 was blocked
08/07/2003 12:20:32 - 190.92.46.194 was blocked
08/07/2003 12:20:21 - 190.92.46.194 was blocked
08/07/2003 12:20:14 - 190.92.46.194 was blocked
08/07/2003 12:20:06 - 190.92.46.194 was blocked
08/07/2003 12:19:38 - 190.92.46.194 was blocked
08/07/2003 12:18:35 - 190.92.46.194 was blocked
08/07/2003 12:18:13 - 190.92.46.194 was blocked
08/07/2003 12:18:12 - 190.92.46.194 was blocked
08/07/2003 12:18:02 - 190.92.46.194 was blocked
08/07/2003 12:17:41 - 202.144.191.1 was banned
08/07/2003 12:17:41 - 94.7.203.177 was banned
08/07/2003 12:17:32 - 190.92.46.194 was blocked
08/07/2003 12:17:06 - 2.218.28.165 was blocked
08/07/2003 12:16:56 - 190.92.46.194 was blocked
08/07/2003 12:16:53 - 190.92.46.194 was blocked
08/07/2003 12:16:45 - 190.92.46.194 was blocked
08/07/2003 12:16:36 - 190.92.46.194 was blocked
08/07/2003 12:15:49 - 190.92.46.194 was blocked
08/07/2003 12:15:18 - 190.92.46.194 was blocked
08/07/2003 12:14:31 - 190.92.46.194 was blocked
08/07/2003 12:13:16 - 193.219.163.162 was blocked
08/07/2003 12:13:16 - 190.92.46.194 was blocked
08/07/2003 12:13:00 - 190.92.46.194 was blocked
08/07/2003 12:12:50 - 190.92.46.194 was blocked
08/07/2003 12:12:34 - 190.92.46.194 was blocked
08/07/2003 12:12:11 - 177.140.72.13 was banned
08/07/2003 12:11:38 - 190.92.46.194 was blocked
08/07/2003 12:11:33 - 190.92.46.194 was blocked
08/07/2003 12:11:26 - 200.138.62.31 was blocked
08/07/2003 12:11:18 - 2.218.28.165 was blocked
08/07/2003 12:11:13 - 190.92.46.194 was blocked
08/07/2003 12:11:09 - 190.92.46.194 was blocked
08/07/2003 12:10:06 - 190.92.46.194 was blocked
08/07/2003 12:10:04 - 190.92.46.194 was blocked
08/07/2003 12:09:29 - 190.92.46.194 was blocked
08/07/2003 12:09:18 - 190.92.46.194 was blocked
08/07/2003 12:08:58 - 190.92.46.194 was blocked
08/07/2003 12:08:56 - 2.218.28.165 was blocked
08/07/2003 12:08:53 - 79.176.57.19 was blocked
08/07/2003 12:08:52 - 2.218.28.165 was blocked
08/07/2003 12:08:50 - 2.218.28.165 was blocked
08/07/2003 12:08:49 - 2.218.28.165 was blocked
08/07/2003 12:08:48 - 2.218.28.165 was blocked
08/07/2003 12:08:48 - 117.244.237.147 was blocked
08/07/2003 12:08:47 - 109.254.49.37 was blocked
08/07/2003 12:08:47 - 84.73.148.235 was blocked
08/07/2003 12:08:47 - 181.166.211.219 was blocked
08/07/2003 12:08:47 - 78.73.241.180 was blocked
08/07/2003 12:08:47 - 189.71.193.1 was blocked
08/07/2003 12:08:47 - 46.27.3.41 was blocked
08/07/2003 12:08:47 - 84.202.13.74 was blocked
08/07/2003 12:08:47 - 186.45.200.81 was blocked
08/07/2003 12:08:47 - 78.104.182.174 was blocked
08/07/2003 12:08:47 - 39.32.197.59 was blocked
08/07/2003 12:08:47 - 122.56.60.1 was blocked
08/07/2003 12:08:47 - 110.174.166.225 was blocked
08/07/2003 12:08:47 - 24.109.132.255 was blocked
08/07/2003 12:08:47 - 14.99.38.8 was blocked
08/07/2003 12:08:17 - 91.73.150.21 was blocked
08/07/2003 12:07:40 - 190.92.46.194 was blocked
08/07/2003 12:07:25 - 190.92.46.194 was blocked
08/07/2003 12:07:09 - 190.92.46.194 was blocked
08/07/2003 12:07:02 - 190.92.46.194 was blocked
08/07/2003 12:07:00 - 190.92.46.194 was blocked
08/07/2003 12:06:21 - 190.92.46.194 was blocked
08/07/2003 12:05:03 - 190.92.46.194 was blocked
08/07/2003 12:04:53 - 190.92.46.194 was blocked
08/07/2003 12:04:30 - 190.92.46.194 was blocked
08/07/2003 12:03:56 - 190.92.46.194 was blocked
08/07/2003 12:03:09 - 190.92.46.194 was blocked
08/07/2003 12:02:15 - 142.166.205.174 was blocked
08/07/2003 12:02:15 - 190.92.46.194 was blocked
08/07/2003 12:02:03 - 190.92.46.194 was blocked
08/07/2003 12:01:31 - 190.92.46.194 was blocked
08/07/2003 12:01:19 - 190.92.46.194 was blocked
08/07/2003 12:00:57 - 190.92.46.194 was blocked
08/07/2003 12:00:51 - 190.92.46.194 was blocked
08/07/2003 12:00:37 - 213.112.18.219 was banned
08/07/2003 12:00:37 - 130.226.139.93 was banned
08/07/2003 12:00:37 - 139.228.39.60 was banned
08/07/2003 12:00:37 - 213.125.120.234 was banned
08/07/2003 12:00:37 - 178.222.90.186 was banned
08/07/2003 12:00:37 - 70.30.114.227 was banned
08/07/2003 12:00:31 - 190.92.46.194 was blocked
08/07/2003 12:00:15 - 121.54.54.131 was blocked
08/07/2003 12:00:12 - 190.92.46.194 was blocked
08/07/2003 12:00:07 - 190.92.46.194 was blocked
08/07/2003 11:58:53 - 2.218.28.165 was blocked
08/07/2003 11:58:47 - 190.92.46.194 was blocked
08/07/2003 11:58:27 - 190.92.46.194 was blocked
08/07/2003 11:58:08 - 190.92.46.194 was blocked
08/07/2003 11:58:06 - 121.54.54.131 was blocked
08/07/2003 11:58:06 - 190.92.46.194 was blocked
08/07/2003 11:57:42 - 190.92.46.194 was blocked
08/07/2003 11:57:34 - 190.92.46.194 was blocked
08/07/2003 11:57:06 - 190.92.46.194 was blocked
08/07/2003 11:56:40 - 190.92.46.194 was blocked
08/07/2003 11:56:22 - 190.92.46.194 was blocked
08/07/2003 11:55:40 - 190.92.46.194 was blocked
08/07/2003 11:55:39 - 190.92.46.194 was blocked
08/07/2003 11:55:28 - 190.92.46.194 was blocked
08/07/2003 11:55:22 - 190.92.46.194 was blocked
08/07/2003 11:55:11 - 2.218.28.165 was blocked
08/07/2003 11:54:16 - 190.92.46.194 was blocked
08/07/2003 11:53:55 - 2.218.28.165 was blocked
08/07/2003 11:53:54 - 190.92.46.194 was blocked
08/07/2003 11:53:54 - 142.166.205.174 was blocked
08/07/2003 11:53:52 - 2.218.28.165 was blocked
08/07/2003 11:53:52 - 182.73.31.94 was blocked
08/07/2003 11:53:51 - 186.45.200.81 was blocked
08/07/2003 11:53:51 - 84.202.13.74 was blocked
08/07/2003 11:53:51 - 46.27.3.41 was blocked
08/07/2003 11:53:51 - 189.71.193.1 was blocked
08/07/2003 11:53:51 - 78.73.241.180 was blocked
08/07/2003 11:53:51 - 181.166.211.219 was blocked
08/07/2003 11:53:51 - 84.73.148.235 was blocked
08/07/2003 11:53:51 - 2.84.135.239 was blocked
08/07/2003 11:53:51 - 89.100.186.250 was blocked
08/07/2003 11:53:51 - 211.198.139.8 was blocked
08/07/2003 11:53:51 - 80.230.24.56 was blocked
08/07/2003 11:53:51 - 68.150.128.45 was blocked
08/07/2003 11:53:38 - 190.92.46.194 was blocked
08/07/2003 11:53:30 - 190.92.46.194 was blocked
08/07/2003 11:53:23 - 190.92.46.194 was blocked
08/07/2003 11:53:22 - 190.92.46.194 was blocked
08/07/2003 11:52:33 - 190.92.46.194 was blocked
08/07/2003 11:51:56 - 218.186.228.70 was blocked
08/07/2003 11:51:49 - 190.92.46.194 was blocked
08/07/2003 11:51:42 - 190.92.46.194 was blocked
08/07/2003 11:51:25 - 190.92.46.194 was blocked
08/07/2003 11:50:40 - 190.92.46.194 was blocked
08/07/2003 11:50:06 - 190.92.46.194 was blocked
08/07/2003 11:49:46 - 190.92.46.194 was blocked
08/07/2003 11:49:41 - 190.92.46.194 was blocked
08/07/2003 11:49:30 - 190.92.46.194 was blocked
08/07/2003 11:49:20 - 190.92.46.194 was blocked
08/07/2003 11:49:19 - 190.92.46.194 was blocked
08/07/2003 11:48:12 - 190.92.46.194 was blocked
08/07/2003 11:47:56 - 190.92.46.194 was blocked
08/07/2003 11:47:39 - 2.218.28.165 was blocked
08/07/2003 11:47:22 - 174.88.4.117 was banned
08/07/2003 11:47:22 - 82.28.207.200 was banned
08/07/2003 11:47:22 - 24.224.225.169 was banned
08/07/2003 11:47:22 - 71.79.7.175 was banned
08/07/2003 11:46:30 - 89.139.27.213 was banned
08/07/2003 11:46:30 - 177.140.72.13 was banned
08/07/2003 11:46:30 - 93.162.69.54 was banned
08/07/2003 11:46:30 - 213.112.18.219 was banned
08/07/2003 11:46:30 - 178.222.90.186 was banned
08/07/2003 11:46:30 - 70.30.114.227 was banned
08/07/2003 11:46:16 - 190.92.46.194 was blocked
08/07/2003 11:45:56 - 190.92.46.194 was blocked
08/07/2003 11:45:25 - 190.92.46.194 was blocked
08/07/2003 11:45:21 - 190.92.46.194 was blocked
08/07/2003 11:45:10 - 218.186.228.70 was blocked
08/07/2003 11:43:58 - 190.92.46.194 was blocked
08/07/2003 11:43:55 - 190.92.46.194 was blocked
08/07/2003 11:42:57 - 190.92.46.194 was blocked
08/07/2003 11:42:50 - 190.92.46.194 was blocked
08/07/2003 11:42:13 - 91.73.150.21 was blocked
08/07/2003 11:42:01 - 190.92.46.194 was blocked
08/07/2003 11:42:00 - 190.92.46.194 was blocked
08/07/2003 11:41:50 - 190.92.46.194 was blocked
08/07/2003 11:41:09 - 190.92.46.194 was blocked
08/07/2003 11:40:42 - 190.92.46.194 was blocked
08/07/2003 11:40:39 - 190.92.46.194 was blocked
08/07/2003 11:40:33 - 177.205.32.93 was blocked
08/07/2003 11:40:24 - 190.92.46.194 was blocked
08/07/2003 11:39:02 - 79.176.57.19 was blocked
08/07/2003 11:39:02 - 117.198.123.169 was blocked
08/07/2003 11:39:02 - 193.219.163.162 was blocked
08/07/2003 11:39:02 - 190.92.46.194 was blocked
08/07/2003 11:39:01 - 177.140.72.13 was banned
08/07/2003 11:39:01 - 115.64.192.106 was banned
08/07/2003 11:39:01 - 46.27.254.202 was banned
08/07/2003 11:38:58 - 79.176.57.19 was blocked
08/07/2003 11:38:58 - 142.166.205.174 was blocked
08/07/2003 11:38:58 - 2.218.28.165 was blocked
08/07/2003 11:38:56 - 14.200.104.126 was blocked
08/07/2003 11:38:56 - 2.218.28.165 was blocked
08/07/2003 11:38:56 - 72.183.35.226 was blocked
08/07/2003 11:38:56 - 122.178.197.242 was blocked
08/07/2003 11:38:56 - 90.191.170.47 was blocked
08/07/2003 11:38:56 - 110.174.166.225 was blocked
08/07/2003 11:38:56 - 101.98.143.73 was blocked
08/07/2003 11:38:18 - 190.92.46.194 was blocked
08/07/2003 11:38:01 - 117.198.123.169 was blocked
08/07/2003 11:37:28 - 190.92.46.194 was blocked
08/07/2003 11:37:05 - 190.92.46.194 was blocked
08/07/2003 11:36:51 - 190.92.46.194 was blocked
08/07/2003 11:36:34 - 190.92.46.194 was blocked
08/07/2003 11:36:33 - 190.92.46.194 was blocked
08/07/2003 11:35:25 - 190.92.46.194 was blocked
08/07/2003 11:35:23 - 190.92.46.194 was blocked
08/07/2003 11:35:20 - 190.92.46.194 was blocked
08/07/2003 11:34:34 - 190.92.46.194 was blocked
08/07/2003 11:34:28 - 122.178.197.242 was blocked
08/07/2003 11:34:08 - 190.92.46.194 was blocked
08/07/2003 11:34:00 - 190.92.46.194 was blocked
08/07/2003 11:33:20 - 190.92.46.194 was blocked
08/07/2003 11:33:15 - 190.92.46.194 was blocked
08/07/2003 11:33:08 - 190.92.46.194 was blocked
08/07/2003 11:32:57 - 190.92.46.194 was blocked
08/07/2003 11:32:33 - 190.92.46.194 was blocked
08/07/2003 11:32:23 - 190.92.46.194 was blocked
08/07/2003 11:31:48 - 182.73.31.94 was blocked
08/07/2003 11:31:45 - 190.92.46.194 was blocked
08/07/2003 11:30:49 - 190.92.46.194 was blocked
08/07/2003 11:30:07 - 190.92.46.194 was blocked
08/07/2003 11:29:58 - 202.147.168.122 was blocked
08/07/2003 11:29:24 - 190.92.46.194 was blocked
08/07/2003 11:29:23 - 190.92.46.194 was blocked
08/07/2003 11:29:22 - 190.92.46.194 was blocked
08/07/2003 11:28:18 - 190.92.46.194 was blocked
08/07/2003 11:27:13 - 190.92.46.194 was blocked
08/07/2003 11:26:52 - 190.92.46.194 was blocked
08/07/2003 11:26:37 - 190.92.46.194 was blocked
08/07/2003 11:26:33 - 190.92.46.194 was blocked
08/07/2003 11:25:51 - 122.178.197.242 was blocked
08/07/2003 11:25:32 - 190.92.46.194 was blocked
08/07/2003 11:24:43 - 190.92.46.194 was blocked
08/07/2003 11:24:04 - 2.218.28.165 was blocked
08/07/2003 11:24:04 - 79.176.57.19 was blocked
08/07/2003 11:24:03 - 2.218.28.165 was blocked
08/07/2003 11:24:02 - 178.233.165.209 was blocked
08/07/2003 11:24:01 - 2.218.28.165 was blocked
08/07/2003 11:24:00 - 123.200.28.77 was blocked
08/07/2003 11:24:00 - 91.202.242.228 was blocked
08/07/2003 11:24:00 - 82.161.151.52 was blocked
08/07/2003 11:24:00 - 96.53.10.62 was blocked
08/07/2003 11:24:00 - 82.75.250.33 was blocked
08/07/2003 11:24:00 - 62.163.172.143 was blocked
08/07/2003 11:24:00 - 193.91.172.178 was blocked
08/07/2003 11:24:00 - 197.148.36.142 was blocked
08/07/2003 11:24:00 - 117.205.110.139 was blocked
08/07/2003 11:24:00 - 99.103.205.37 was blocked
08/07/2003 11:24:00 - 103.240.192.82 was blocked
08/07/2003 11:24:00 - 172.2.100.112 was blocked
08/07/2003 11:24:00 - 98.231.105.95 was blocked
08/07/2003 11:24:00 - 197.155.230.58 was blocked
08/07/2003 11:24:00 - 198.84.200.70 was blocked
08/07/2003 11:24:00 - 65.130.210.50 was blocked
08/07/2003 11:24:00 - 113.11.241.245 was blocked
08/07/2003 11:24:00 - 183.89.50.68 was blocked
08/07/2003 11:24:00 - 84.202.13.74 was blocked
08/07/2003 11:23:24 - 190.92.46.194 was blocked
08/07/2003 11:23:01 - 190.92.46.194 was blocked
08/07/2003 11:21:29 - 78.251.147.106 was blocked
08/07/2003 11:21:16 - 190.92.46.194 was blocked
08/07/2003 11:21:13 - 190.92.46.194 was blocked
08/07/2003 11:21:00 - 190.92.46.194 was blocked
08/07/2003 11:20:28 - 190.92.46.194 was blocked
08/07/2003 11:20:08 - 190.92.46.194 was blocked
08/07/2003 11:19:40 - 190.92.46.194 was blocked
08/07/2003 11:19:31 - 190.92.46.194 was blocked
08/07/2003 11:19:15 - 190.92.46.194 was blocked
08/07/2003 11:19:06 - 190.92.46.194 was blocked
08/07/2003 11:17:26 - 190.92.46.194 was blocked
08/07/2003 11:16:59 - 190.92.46.194 was blocked
08/07/2003 11:15:59 - 190.92.46.194 was blocked
08/07/2003 11:15:01 - 190.92.46.194 was blocked
08/07/2003 11:14:47 - 190.92.46.194 was blocked
08/07/2003 11:14:45 - 190.92.46.194 was blocked
08/07/2003 11:14:34 - 190.92.46.194 was blocked
08/07/2003 11:13:06 - 2.218.28.165 was blocked
08/07/2003 11:12:39 - 190.92.46.194 was blocked
08/07/2003 11:12:24 - 190.92.46.194 was blocked
08/07/2003 11:12:19 - 190.92.46.194 was blocked
08/07/2003 11:12:15 - 190.92.46.194 was blocked
08/07/2003 11:11:14 - 190.92.46.194 was blocked
08/07/2003 11:10:53 - 190.92.46.194 was blocked
08/07/2003 11:10:38 - 190.92.46.194 was blocked
08/07/2003 11:10:05 - 2.218.28.165 was blocked
08/07/2003 11:10:05 - 79.176.57.19 was blocked
08/07/2003 11:09:59 - 190.92.46.194 was blocked
08/07/2003 11:09:40 - 190.92.46.194 was blocked
08/07/2003 11:09:15 - 190.92.46.194 was blocked
08/07/2003 11:09:15 - 218.186.228.70 was blocked
08/07/2003 11:09:13 - 218.186.228.70 was blocked
08/07/2003 11:09:09 - 190.92.46.194 was blocked
08/07/2003 11:09:09 - 2.218.28.165 was blocked
08/07/2003 11:09:08 - 190.92.46.194 was blocked
08/07/2003 11:09:06 - 178.233.165.209 was blocked
08/07/2003 11:09:06 - 2.218.28.165 was blocked
08/07/2003 11:09:05 - 218.186.228.70 was blocked
08/07/2003 11:09:04 - 183.89.50.68 was blocked
08/07/2003 11:09:04 - 113.11.241.245 was blocked
08/07/2003 11:09:04 - 92.99.2.195 was blocked
08/07/2003 11:09:04 - 89.100.178.99 was blocked
08/07/2003 11:09:04 - 90.191.170.47 was blocked
08/07/2003 11:09:04 - 86.107.76.157 was blocked
08/07/2003 11:09:04 - 2.122.45.113 was blocked
08/07/2003 11:09:04 - 46.27.3.41 was blocked
08/07/2003 11:09:04 - 124.186.108.48 was blocked
08/07/2003 11:09:04 - 123.3.100.246 was blocked
08/07/2003 11:09:04 - 92.99.118.50 was blocked
08/07/2003 11:09:04 - 123.200.28.77 was blocked
08/07/2003 11:09:04 - 91.202.242.228 was blocked
08/07/2003 11:09:04 - 82.161.151.52 was blocked
08/07/2003 11:08:49 - 190.92.46.194 was blocked
08/07/2003 11:07:54 - 190.92.46.194 was blocked
08/07/2003 11:07:47 - 190.92.46.194 was blocked
08/07/2003 11:07:25 - 190.92.46.194 was blocked
08/07/2003 11:07:18 - 190.92.46.194 was blocked
08/07/2003 11:06:47 - 190.92.46.194 was blocked
08/07/2003 11:05:54 - 190.92.46.194 was blocked
08/07/2003 11:05:47 - 190.92.46.194 was blocked
08/07/2003 11:05:29 - 190.92.46.194 was blocked
08/07/2003 11:05:22 - 190.92.46.194 was blocked
08/07/2003 11:04:16 - 190.92.46.194 was blocked
08/07/2003 11:04:06 - 190.92.46.194 was blocked
08/07/2003 11:04:02 - 190.92.46.194 was blocked
08/07/2003 11:03:21 - 190.92.46.194 was blocked
08/07/2003 11:03:17 - 79.176.57.19 was blocked
08/07/2003 11:02:25 - 190.92.46.194 was blocked
08/07/2003 11:01:39 - 218.186.228.70 was blocked
08/07/2003 11:01:32 - 190.92.46.194 was blocked
08/07/2003 11:01:23 - 190.92.46.194 was blocked
08/07/2003 11:00:18 - 190.92.46.194 was blocked
08/07/2003 11:00:00 - 190.92.46.194 was blocked
08/07/2003 10:59:39 - 190.92.46.194 was blocked
08/07/2003 10:59:30 - 190.92.46.194 was blocked
08/07/2003 10:58:08 - 190.92.46.194 was blocked
08/07/2003 10:57:32 - 190.92.46.194 was blocked
It seems that libtorrent already bans a lot of IPs which means that you are trying to download torrents that have a lot of active bad peers.
You could try using an IPFilter in the settings or a program like peerblock: http://www.peerblock.com/
However, I don't know if you can actually get your torrents to finish. Do other bt clients finish those torrents?
EDIT: If you are connecting through wifi, then it might be a connection problem between you and the router or faulty antennas.
coldlm
Post by coldlm »
Yeah only some torrents takes hours to download and cant finish,
also is all this blocked IPs normal or is it way too much on my qbit!
and no the PC i use to download torrent is wired to my router not using it on wifi network!
okay thanks i will give that one a try and see!
ciaobaby
Post by ciaobaby »
Why make qBT work harder than it needs to?
Copy and paste them into a spreadsheet, sort them by IP number and deny access to qBT listening port  in your router SPI firewall using CIDR block notation to group the ranges.
fusk
Post by fusk »
I'm wondering why it's banning so many, currently i don't have any major issues with qbit, but it does ban a lot of ip's even from private trackers where bad seeders or fairly rare, and dealt with swiftly. Wondering what it's rules are.
I had this too lately with a certain torrent that the wasted amount gets around 400MB+ (filesize is 4.3GB total) and thats pretty high. Till the torrent was finished I had downloaded well over 4.3GB. I've tested the same torrent within uTorrent 2.2.1 (Yes.. the only best version) and only got 12MB+- wasted after completion which is weird. I always have uTorrent 2.2.1 installed on my system as a backup or if I need to try out things like this.
Also blocked ip's gets a whole list with me too and I don't know why there are getting so many blocked. Simple text with explanation why they are getting blocked would be nice, but I don't know if this is possible. qBittorrent seems very, very strict seeing the list and probably banning the good ones too on the long run.
coldlm
Post by coldlm »
[quote="ciaobaby"]
Yeah thats another option but it doesnt seem to work since i tried your suggestion with another trick to block bad IPs,,,,
the thing is my wasted downloads only seems to get high (seriously high, in 3GB download i wasted 1.7GB) when downloading a torrent with a lot of files on it,(like top gear season 21 for example i wasted 1GB but on another torrenter the wasted downloads was like 10mb) so the problem is only with Qbit!!!
now im facing another big PROBLEM,
qbit never reaches max speed and it never go passes 40% of my speed, even when all torrents are stopped my internet gets really slow, only when i close Qbit then everything goes back to normal!!!!
coldlm
Post by coldlm »
[quote="Nemo"]
Oh man mine wastses too much like 1.7 gigs in 3.9 gig torrent!
but i think mine only wastes too much when downloading torrents with a lot of  files on them like tv shows full seasons...
fusk
Post by fusk »
Okay i do not have that problem, i might waste 1/2 mb on a 20gb download. I'm more curious about all the ip's it's banning.
With the most torrents im only having a few MB's waisted which is normal. Only with a few torrents (same releaser and new shows every week) I get too much loss of data. I think that with some torrents people are sending bad data on purpose (atleast thats what I think), or just unlucky that they are downloading/seeding the same torrent as you do. coldlm, your data is way too much, do you only get it with that certan torrent/show as I do perhaps? Then again there could be other things playing part on this too like your ISP or having bad memory units (or just a bad torrent in general with bad peers every time). Im researching this on my side still.
About the ip's; its too much in my eye too and im not sure for what reason. There might be good ones that are getting blocked also.
I've found a similiar report on libtorrent about this:
https://code.google.com/p/libtorrent/issues/detail?id=575
however, it's probably a good idea to add the reason of a peer being blocked in the alert.
Thats what Arvid said himself, libtorrent author, and I completely agree to see a reason for the peers getting blocked. Also a way to clear the blocklist (unblock everyone) would be nice.
