Lords after upgrade to 3.1.9 qBittoeent, the program is crashing all the time is aparacendo windows will try to find a solution there I have to leave by manager, what to do to resolve this problem as I continue to use it.
Thank you all.
QBitroeent 3.1.9 crashing on windows 7
Re: QBitroeent 3.1.9 crashing on windows 7
1. Download Windbg
2. Start WindDbg and qbittorrent
3. In WinDbg File->Attach to process and choose the qbittorrent.exe process
4. Debug->Go
5. When qbittorrent crashes write this in the WinDbg command subwindow "!analyze -v"
6. Copy the output.
4. Debug->Go
6. Copy the output.
If you use the 64bit WinBdg then before step 5 insert this "!wow64exts.sw"
* Exception Analysis *
***** OS symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: ntdll!_PEB ***
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
*** work. ***
*** Type referenced: nt!IMAGE_NT_HEADERS32 ***
FAULTING_IP:
ntdll!DbgBreakPoint+0
00000000`76d90590 cc int 3
EXCEPTION_RECORD: ffffffffffffffff -- (.exr 0xffffffffffffffff)
ExceptionAddress: 0000000076d90590 (ntdll!DbgBreakPoint)
ExceptionCode: 80000003 (Break instruction exception)
ExceptionFlags: 00000000
NumberParameters: 1
Parameter[0]: 0000000000000000
FAULTING_THREAD: 00000000000010ac
DEFAULT_BUCKET_ID: WRONG_SYMBOLS
PROCESS_NAME: qbittorrent.exe
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
MODULE_NAME: ntdll
FAULTING_MODULE: 0000000076d40000 ntdll
DEBUG_FLR_IMAGE_TIMESTAMP: 521eaf24
ERROR_CODE: (NTSTATUS) 0x80000003 - {EXCE O} Ponto de interrup o Foi alcan ado um ponto de interrup o.
EXCEPTION_CODE: (HRESULT) 0x80000003 (2147483651) - Um ou mais argumentos s o inv lidos
EXCEPTION_PARAMETER1: 0000000000000000
APP: qbittorrent.exe
PRIMARY_PROBLEM_CLASS: WRONG_SYMBOLS
BUGCHECK_STR: APPLICATION_FAULT_WRONG_SYMBOLS
LAST_CONTROL_TRANSFER: from 0000000076e37f48 to 0000000076d90590
STACK_TEXT:
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: ntdll!DbgBreakPoint+0
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntdll.dll
STACK_COMMAND: ~2s ; kb
FAILURE_BUCKET_ID: WRONG_SYMBOLS_80000003_ntdll.dll!DbgBreakPoint
WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOne/qb ... Retriage=1
Followup: MachineOwner
*** work. ***
*** work. ***
FAULTING_IP:
NumberParameters: 1
MODULE_NAME: ntdll
STACK_TEXT:
FOLLOWUP_IP:
Microsoft (R) Windows Debugger Version 6.2.9200.16384 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
*** wait with pending attach
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
ModLoad: 00000000`01270000 00000000`0211b000 C:\Program Files (x86)\qBittorrent\qbittorrent.exe
ModLoad: 00000000`76d40000 00000000`76ee9000 C:\Windows\SYSTEM32\ntdll.dll
ModLoad: 00000000`76f20000 00000000`770a0000 ntdll.dll
ModLoad: 00000000`748e0000 00000000`7491f000 C:\Windows\SYSTEM32\wow64.dll
ModLoad: 00000000`74880000 00000000`748dc000 C:\Windows\SYSTEM32\wow64win.dll
ModLoad: 00000000`74870000 00000000`74878000 C:\Windows\SYSTEM32\wow64cpu.dll
ModLoad: 00000000`74ac0000 00000000`74bd0000 KERNEL32.dll
ModLoad: 00000000`752e0000 00000000`75327000 KERNELBASE.dll
ModLoad: 00000000`6f3d0000 00000000`6f4bb000 dbghelp.dll
ModLoad: 00000000`754c0000 00000000`7556c000 msvcrt.dll
ModLoad: 00000000`769f0000 00000000`76a90000 ADVAPI32.dll
ModLoad: 00000000`76900000 00000000`76919000 SECHOST.dll
ModLoad: 00000000`75330000 00000000`75420000 RPCRT4.dll
ModLoad: 00000000`74940000 00000000`749a0000 SspiCli.dll
ModLoad: 00000000`74930000 00000000`7493c000 CRYPTBASE.dll
ModLoad: 00000000`756c0000 00000000`7630a000 SHELL32.dll
ModLoad: 00000000`767b0000 00000000`76807000 SHLWAPI.dll
ModLoad: 00000000`76a90000 00000000`76b20000 GDI32.dll
ModLoad: 00000000`75570000 00000000`75670000 USER32.dll
ModLoad: 00000000`74d00000 00000000`74d0a000 LPK.dll
ModLoad: 00000000`74d10000 00000000`74dad000 USP10.dll
ModLoad: 00000000`70ce0000 00000000`70d05000 POWRPROF.dll
ModLoad: 00000000`763a0000 00000000`7653d000 SETUPAPI.dll
ModLoad: 00000000`76780000 00000000`767a7000 CFGMGR32.dll
ModLoad: 00000000`76870000 00000000`768ff000 OLEAUT32.dll
ModLoad: 00000000`74de0000 00000000`74f3c000 ole32.dll
ModLoad: 00000000`76540000 00000000`76552000 DEVOBJ.dll
ModLoad: 00000000`75420000 00000000`7549b000 COMDLG32.dll
ModLoad: 00000000`71d00000 00000000`71e9e000 COMCTL32.dll
ModLoad: 00000000`76810000 00000000`76870000 IMM32.dll
ModLoad: 00000000`76920000 00000000`769ec000 MSCTF.dll
ModLoad: 00000000`73a90000 00000000`73ac2000 WINMM.dll
ModLoad: 00000000`75170000 00000000`751a5000 WS2_32.dll
ModLoad: 00000000`76330000 00000000`76336000 NSI.dll
ModLoad: 00000000`74560000 00000000`7459c000 MSWSOCK.dll
ModLoad: 00000000`749a0000 00000000`74ac0000 CRYPT32.dll
ModLoad: 00000000`74f40000 00000000`74f4c000 MSASN1.dll
ModLoad: 00000000`70f30000 00000000`70fb0000 UxTheme.dll
ModLoad: 00000000`6efc0000 00000000`6efd3000 dwmapi.dll
ModLoad: 00000000`72ed0000 00000000`72ee7000 USERENV.dll
ModLoad: 00000000`74800000 00000000`7480b000 profapi.dll
ModLoad: 00000000`74bd0000 00000000`74c53000 CLBCatQ.DLL
ModLoad: 00000000`74810000 00000000`74826000 CRYPTSP.dll
ModLoad: 00000000`747c0000 00000000`747fb000 RSAENH.dll
ModLoad: 00000000`746e0000 00000000`746e6000 WSHIP6.dll
ModLoad: 00000000`746f0000 00000000`746f5000 WSHTCPIP.dll
ModLoad: 00000000`720c0000 00000000`72104000 DNSAPI.dll
ModLoad: 00000000`72060000 00000000`72087000 WLIDNSP.dll
ModLoad: 00000000`756a0000 00000000`756a5000 PSAPI.DLL
ModLoad: 00000000`74540000 00000000`7455c000 IPHLPAPI.DLL
ModLoad: 00000000`746d0000 00000000`746d7000 WINNSI.DLL
ModLoad: 00000000`71fd0000 00000000`72008000 fwpuclnt.dll
ModLoad: 00000000`71f50000 00000000`71f56000 rasadhlp.dll
ModLoad: 00000000`743c0000 00000000`743ce000 RpcRtRemote.dll
(b14.1154): Break instruction exception - code 80000003 (first chance)
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\ntdll.dll -
ntdll!DbgBreakPoint:
0:016> !analyze -v
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** work. ***
*** work. ***
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\wow64cpu.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\wow64.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntdll.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ole32.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for MSWSOCK.dll -
FAULTING_IP:
NumberParameters: 1
FAULTING_THREAD: 0000000000001154
MODULE_NAME: ntdll
STACK_TEXT:
00000000`010ff788 00000000`76e37f48 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!DbgBreakPoint
00000000`010ff790 00000000`76da4990 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!DbgUiRemoteBreakin+0x38
00000000`010ff7c0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlIsDosDeviceName_U+0xaf70
FOLLOWUP_IP:
STACK_COMMAND: ~16s ; kb
0:016> !analyze -v
*** work. ***
*** work. ***
FAULTING_IP:
NumberParameters: 1
MODULE_NAME: ntdll
STACK_TEXT:
FOLLOWUP_IP:
Did you remember to issue "!wow64exts.sw" before "!analyze -v"?
If not, try again and then copy the text into the [ code] tags.
Now yes, as explained and this is the result:
ModLoad: 00000000`00a10000 00000000`018bb000 C:\Program Files (x86)\qBittorrent\qbittorrent.exe
ModLoad: 00000000`77460000 00000000`77609000 C:\Windows\SYSTEM32\ntdll.dll
ModLoad: 00000000`77640000 00000000`777c0000 ntdll.dll
ModLoad: 00000000`75000000 00000000`7503f000 C:\Windows\SYSTEM32\wow64.dll
ModLoad: 00000000`74fa0000 00000000`74ffc000 C:\Windows\SYSTEM32\wow64win.dll
ModLoad: 00000000`74f90000 00000000`74f98000 C:\Windows\SYSTEM32\wow64cpu.dll
ModLoad: 00000000`76940000 00000000`76a50000 KERNEL32.dll
ModLoad: 00000000`77140000 00000000`77187000 KERNELBASE.dll
ModLoad: 00000000`65ea0000 00000000`65f8b000 dbghelp.dll
ModLoad: 00000000`77190000 00000000`7723c000 msvcrt.dll
ModLoad: 00000000`76d70000 00000000`76e10000 ADVAPI32.dll
ModLoad: 00000000`76ec0000 00000000`76ed9000 SECHOST.dll
ModLoad: 00000000`76680000 00000000`76770000 RPCRT4.dll
ModLoad: 00000000`75060000 00000000`750c0000 SspiCli.dll
ModLoad: 00000000`75050000 00000000`7505c000 CRYPTBASE.dll
ModLoad: 00000000`756e0000 00000000`7632a000 SHELL32.dll
ModLoad: 00000000`75650000 00000000`756a7000 SHLWAPI.dll
ModLoad: 00000000`76a50000 00000000`76ae0000 GDI32.dll
ModLoad: 00000000`75100000 00000000`75200000 USER32.dll
ModLoad: 00000000`76400000 00000000`7640a000 LPK.dll
ModLoad: 00000000`76e10000 00000000`76ead000 USP10.dll
ModLoad: 00000000`70e40000 00000000`70e65000 POWRPROF.dll
ModLoad: 00000000`75380000 00000000`7551d000 SETUPAPI.dll
ModLoad: 00000000`750c0000 00000000`750e7000 CFGMGR32.dll
ModLoad: 00000000`76560000 00000000`765ef000 OLEAUT32.dll
ModLoad: 00000000`75200000 00000000`7535c000 ole32.dll
ModLoad: 00000000`75360000 00000000`75372000 DEVOBJ.dll
ModLoad: 00000000`765f0000 00000000`7666b000 COMDLG32.dll
ModLoad: 00000000`74d70000 00000000`74f0e000 COMCTL32.dll
ModLoad: 00000000`76ae0000 00000000`76b40000 IMM32.dll
ModLoad: 00000000`77070000 00000000`7713c000 MSCTF.dll
ModLoad: 00000000`74100000 00000000`74132000 WINMM.dll
ModLoad: 00000000`77030000 00000000`77065000 WS2_32.dll
ModLoad: 00000000`76670000 00000000`76676000 NSI.dll
ModLoad: 00000000`74960000 00000000`7499c000 MSWSOCK.dll
ModLoad: 00000000`75520000 00000000`75640000 CRYPT32.dll
ModLoad: 00000000`77020000 00000000`7702c000 MSASN1.dll
ModLoad: 00000000`71b90000 00000000`71c10000 UxTheme.dll
ModLoad: 00000000`6f760000 00000000`6f773000 dwmapi.dll
ModLoad: 00000000`71210000 00000000`71227000 USERENV.dll
ModLoad: 00000000`74f40000 00000000`74f4b000 profapi.dll
ModLoad: 00000000`76360000 00000000`763e3000 CLBCatQ.DLL
ModLoad: 00000000`74d50000 00000000`74d66000 CRYPTSP.dll
ModLoad: 00000000`74d10000 00000000`74d4b000 RSAENH.dll
ModLoad: 00000000`74950000 00000000`74956000 WSHIP6.dll
ModLoad: 00000000`74c60000 00000000`74c65000 WSHTCPIP.dll
ModLoad: 00000000`73e30000 00000000`73e74000 DNSAPI.dll
ModLoad: 00000000`73e00000 00000000`73e27000 WLIDNSP.dll
ModLoad: 00000000`76b40000 00000000`76b45000 PSAPI.DLL
ModLoad: 00000000`74930000 00000000`7494c000 IPHLPAPI.DLL
ModLoad: 00000000`74920000 00000000`74927000 WINNSI.DLL
ModLoad: 00000000`72a00000 00000000`72a38000 fwpuclnt.dll
ModLoad: 00000000`74460000 00000000`74466000 rasadhlp.dll
ModLoad: 00000000`748f0000 00000000`748fe000 RpcRtRemote.dll
ModLoad: 00000000`10000000 00000000`10054000 OpenText32.dll
ModLoad: 00000000`71b50000 00000000`71b8c000 OLEACC.dll
ModLoad: 00000000`72ae0000 00000000`72b64000 COMCTL32.dll
(61c.15e8): Break instruction exception - code 80000003 (first chance)
00000000`774b0590 cc int 3
0:015> !wow64exts.sw
Switched to 32bit mode
0:015:x86> !analyze -v
*** work. ***
*** work. ***
*** ERROR: Symbol file could not be found. Defaulted to export symbols for KERNEL32.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for USER32.dll -
*** ERROR: Symbol file could not be found. Defaulted to export symbols for WS2_32.dll -
FAULTING_IP:
774b0590 cc int 3
ExceptionAddress: 00000000774b0590 (ntdll!DbgBreakPoint)
NumberParameters: 1
FAULTING_THREAD: 00000000000015e8
FAULTING_MODULE: 0000000077460000 ntdll
DEBUG_FLR_IMAGE_TIMESTAMP: 521ea8e7
LAST_CONTROL_TRANSFER: from 0000000000000000 to 00000000776501b4
STACK_TEXT:
00000000 00000000 00000000 00000000 00000000 ntdll_77640000!RtlUserThreadStart
FOLLOWUP_IP:
ntdll_77640000!RtlUserThreadStart+0
776501b4 89442404 mov dword ptr [esp+4],eax
SYMBOL_NAME: ntdll!RtlUserThreadStart+0
MODULE_NAME: ntdll_77640000
STACK_COMMAND: ~15s ; kb
FAILURE_BUCKET_ID: WRONG_SYMBOLS_80000003_ntdll.dll!RtlUserThreadStart
*** work. ***
*** work. ***
FAULTING_IP:
774b0590 cc int 3
NumberParameters: 1
STACK_TEXT:
FOLLOWUP_IP:
