Same problem here, speeds limit in Qbittorrent (3.1.5 on LinuxMint 15 Mate) are totally ignored. (Using the GUI)
I have even a problem with the web remote interface that doesn't show the list of file that are downloading
I edited the qbittorrent.conf setting Connection\GlobalUPLimit=10 but nothing happened, Qbittorrent i still downloading to the max speed
Before that I did an upgrade from Qbittorrrent 3.0.9 to 3.1.5 thinking to fix that but same issues ( I added the official PPA to install it )
I mark everything in the speed limit option but everything is ignored
I used to use Qbittorrent in the past and I always used speed limits to manage my connections and it always worked
