Uploading issues via proxy.sh proxy settings...
reklaimer
Post by reklaimer »
Hello everyone.
I am using my VPN's proxy setting in my qbittorrent client on my Ubuntu 12 machine. I have confirmed that the proxy does work by using some online tools. However, I am also using a private torrent tracker. I can download the torrents just fine and without issue. However, I am not seeding much. Not nearly as much as I think I should. Since I am using a private tracker, I have a ratio I would like to keep! Is this a normal occurrence? Or am I doing something wrong?
ciaobaby
Re: Uploading issues via proxy.sh proxy settings...
Post by ciaobaby »
Seeding and proxy servers simply do not go hand in hand, your chances of being 'connectable' are somewhere between 'slim' and 'none'.
reklaimer
Post by reklaimer »
Ah, so would you suggest that just using my VPN instead would be a better choice?
VPN will also make you passive.
If you want to retain your seeding capability, get a seedserver.
Probably one with SFTP support, so you can get your files safely with encryption.
(But if you can just connect via FTP through your proxy... that works too.)
