nsis how to package qBittorrent
Rogue_Spider
Post by Rogue_Spider »
?does anyone know how to execute nsis script to package qbit project?
how to not on build page could someone add?
i mean to say yes in src windows folder is instructions but they are a bit outdated and unclear
Re: nsis how to package qBittorrent
If you are familiar with the nsis packaging you would find the instructions clear enough IMO.
Where are you stuck?
Rogue_Spider
i must be doing something wrong followed instructions moved translations in folder and am getting
Error: Can't open language file - "C:\Program Files\NSIS\Contrib\Language files\English.nlf"!
which is true that folder C:\Program Files\NSIS\Contrib\
contains no language files at all
did i miss something in options that points to lang files?
or is this a missing plugin?
Those are the core languages files that are distributed/install with nsis.
What version of nsis have you installed?
Rogue_Spider
3.0a1 removed it and installed 3.0a2 now
that fixed it ;> thanks sledge
