Lost Upload and Download capabilities with new version.
blackmark2010
Post by blackmark2010 »
I updated to 3.1.9.2 on my Windows 7 computer behind a VPN.  Now nothing is happening - no DHT nodes, nothing.  Any suggestions?
Moved to the right section.
Nemo.
Muzak
Re: Lost Upload and Download capabilities with new version.
Post by Muzak »
Try removing the firewall rule in the windows firewall (or whatever firewall you might use) and recreating.  Sometimes updates are not recognized by Microsloth and your traffic gets blocked.
blackmark2010
I have an ESET firewall, and I don't know what to do.  I'm reading about firewall rules - and it's like reading a foreign language (sorry, I'm somewhat monolinguistic). ???
ciaobaby
Post by ciaobaby »
Turn the firewall off, software firewalls are pointless if you are behind a NAT router and/or a VPN.
blackmark2010
I turned it off for an hour - no change!
ciaobaby
Post by ciaobaby »
Did you restart qBT after dropping it?
blackmark2010
Yes.  qBittorrent off, firewall off, pause for ESET to show firewall is down, restart qBittorent, pause, no DHT nodes.
ciaobaby
Post by ciaobaby »
What colour is the connection indicator on the status bar?
Since you're connecting through a VPN, we must eliminate the prospect that it is a VPN issue. So please download the 3.1.9 again and do a test run. If it works we'll to look furhter into 3.1.9.2.
Link to 3.1.9 installer: http://sourceforge.net/projects/qbittor ... e/download
