21/06/2014 22:24:33 - Reason: xxx file (D:/temp/xxx.avi) error: Wskazuje, ?e kontynuowanie operacji nie jest mo?liwe bez zablokowania jej dla We/Wy
21/06/2014 22:24:33 - An I/O error occurred, 'xxx' paused.
GTranslate: "Indicates that the continuing operation is not possible without blocking it for I / O"
After resume, it happens again after couple of seconds. After recheck, it works for one day, and then happens again with another file.
Are those media files? If yes, do you run an indexing program at the background? Or eg foobar2000 which continuously scans the library folders you have set for new files and tries to read the metadata from them in order to update the database.
Drive is new, 200GB free space on partition, I already run chkdsk in readonly mode - show nothing (I try /r later), S.M.A.R.T shows nothing, I try to defragment now. Permissions should not be a problem - I always download into this location.
These are avi files. My audio library is located in another folder. "d:\temp\" should not be indexed by system (or any other program). Avast may check something (but why avi?). I watched another movie from another folder when this happened.
[quote="gwarser"]These are avi files. My audio library is located in another folder. "d:\temp" should not be indexed by system (or any other program). Avast may check something (but why avi?). I watched another movie from another folder when this happened.
Are you sure that Windows itself doesn't try to index them to create the preview for the file manager?
Try enabling the .!qB file extension for incomplete files in the settings(and make sure that qbt renames those files). This should keep any indexing programs away.
Thumbnails are created in background? I was pretty sure files are scanned when folder is opened.
I checked again in control panel, and "d:\temp" IS indexed by Windows Search. I probably set this long ago. I try deselecting next time.
I first check whether defragmentation helped. All is good for now.
I know about thumbs.db and this new thumbnail database in Vista+, but they are not created when computer is in idle state. Explorer window must be opened to start generating thumbnails.
Initially yes, provided "Thumbnail" view is activated, but once they have been created, or if the folder is set as containing "images" or "videos" they will be updated as a background task.
Problem started again. Disabling Windows Search indexing didn't help. I tried recording log in the Process Monitor http://technet.microsoft.com/en-us/sysi ... s/bb896645 Only qBt touches this file. I see one `CANT WAIT` and two `BUFFER OVERFLOW Control: FSCTL_QUERY_ALLOCATED_RANGES` events. sledgehammer_999, if you want I can send you full log.
PM send
Shortened csv http://pastebin.com/DU8a2zU9
