Change tray icon in gnome?
piole
Post by piole »
how do i change the tray icon?
i use faenza icon theme and i want to make a monocromatic icon for qbittorrent to match with all other in system tray
'ive tried putting a qbittorrent.png on the icon theme, and it work for the applications menu entry and the taskbar, but had no effect on the system tray
Vladi
Re: Change tray icon in gnome?
Post by Vladi »
It will be a feature in 2.8 I think.
Nigelist
Post by Nigelist »
[quote="Vladi"]
[/quote]Latest version 3.0.5
Ability to put an icon in the system tray is still no.
P.S. I apologize for my English. I do not speak English, and used Google Translate.
ironcross
Post by ironcross »
[quote="Nigelist"]
Don't worry. It's almost correct and we can understand you without a problem.
Nigelist
Post by Nigelist »
[quote="ironcross"]
[quote="Nigelist"]
[/quote]Is it possible to put a different icon in the system tray?
