Retrieving Metadata
dodge ram
Retrieving Metadata
Post by dodge ram »
qBittorrent  V.3.1.8
OS            UE 4.2 (Ubuntu 14.04 W/ Mate)
port used for incoming connections: 55599
I have been running qBit for awhile with no problems. I had a hard drive crash and had to do a nuke and pave. After setting up qBit I do a search with no problem but when I try to download the file the bar for Retrieving Metadata keeps going back and forth and stays that way. Before my crash it might only do it for 30 seconds at the most. Right now I am on 15 minutes for this file. This happens for all files.  Anyone have any ideas why this could be happening? Thanks
ciaobaby
Re: Retrieving Metadata
Post by ciaobaby »
update to 3.1.9.2 or 3.2.0a, then try.
