Hi, QB
first ,
How about new option for deletion ? (options-advanced)
deletion : .torrent /.torrent and data / data (three options)
second,
Availability, NEW column in Transfer pannel
That number tells you how many unique copies of the file are available between yourself and the peers you're connected to. If this is less than 1, you most likely will not be able to complete the torrent. The only thing you can do is wait and hope a seeder hops onto the torrent to allow you to complete it. You can also try and request a "reseed" on the tracker's forum. Sometimes, this may never happen because the torrent was abandoned, and you may need to find the torrent elsewhere.
Best regards
New option for deletion
Re: New option for deletion
Hi and welcome,
First;
Near same feature is requested already and has been marked for v3.2.0:
https://github.com/qbittorrent/qBittorrent/issues/1827
Second:
If you click a torrent and then ''General'' under qBittorrent you will see the availability bar. A seperate column isnt there (yet). I had requested something similiar too:
https://github.com/qbittorrent/qBittorrent/issues/1632
https://github.com/qbittorrent/qBittorrent/issues/1630
These are also marked for the new release v3.2.0:
First;
Second:
