Hello,
So I'd like to know if it's possible to retrieve a .torrent file from a completed download. I don't mean just the files on the disk, I actually mean the ones that still shows on the qBittorrent's GUI. I had forgot to set to save the .torrent files and now I totally lost some of those (and I can't find them back =\). So, can I somehow generate/export the .torrent from the torrents that are active on qBittorrent?
Is it possible to retrieve a .torrent file from a completed download?
Re: Is it possible to retrieve a .torrent file from a completed download?
Search for the "BT_backup" folder somewhere on your disk.
The torrents are saved by their infohash. You can see the infohash from the GUI.
Don't delete them from there because they'll also disappear from the GUI(after you restart it).
