I am trying to setup it up to run as a private tracker.
It has installed ok and I am able to download torrents.
The web interface runs fine.
I have created a torrent.
I have confirmed qbittorrent loads the conf file.
I have set:
Advanced\trackerEnabled=true
Advanced\trackerPort=9001
I have port forwarded port 9001 on my router
This is my output when I run qbittorrent
16/04/2015 19:05:47 - '/root/.local/share/data/qBittorrent/BT_backup/0ad11ed151d7ae99135ed83ec4e796bd074de6ec.torrent' resumed. (fast resume)
******** Information ********
To control qBittorrent, access the Web UI at http://localhost:8080
The Web UI administrator user name is: admin
The Web UI administrator password is still the default one: adminadmin
This is a security risk, please consider changing your password from program preferences.
16/04/2015 19:05:47 - The Web UI is listening on port 8080
16/04/2015 19:05:48 - qBittorrent failed listening on interface 0.0.0.0 port: TCP/37358. Reason: Address family not supported by protocol
16/04/2015 19:05:48 - qBittorrent is successfully listening on interface 0.0.0.0 port: TCP/6881
16/04/2015 19:05:48 - qBittorrent failed listening on interface 0.0.0.0 port: TCP/6881. Reason: Address family not supported by protocol
16/04/2015 19:05:48 - External IP: 58.84.162.0
16/04/2015 19:05:53 - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: 6881
16/04/2015 19:05:53 - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: 8080
I have port forwarded my webui can can access that from the external ip i.e. 58.84.162.1:8080 so I am pretty sure the port forwarding is working.
Any ideas what could be wrong? Is there somewhere special that I need to put the .torrent file? or the files themselves. Is there a log I can view?
