[DONE] SMF UPDATE IMMINENT
So because I already stated the SSL switch will cause some downtime, here is some more downtime.
New security update is out, I will be applying it in the next few minutes.
Buckle up!
Re: SMF UPDATE IMMINENT
Update is installed, check if everything is fine.
