[official]qBittorrent 3.2.5 installer - Built with MSVC 2013
Link to 3.2.5 post-> index.php/topic,3447.msg20035.html#msg20035
*****ORIGINAL POST BELOW****
Here is qBittorrent 3.2.0 built with MSVC 2013 express.
3.2.0 link-> http://www.fosshub.com/qBittorrent.html
Libraries's version used:
Libtorrent: 1.0.4+svn11046
Qt: 4.8.6
Boost: 1.55.0
Last edited by sledgehammer_999 on Sat Oct 31, 2015 4:18 pm, edited 1 time in total.
Gúgolplex
Re: [official]qBittorrent 3.2.0 installer - Built with MSVC 2013
Post by Gúgolplex »
Thanks very much!
tekko
Post by tekko »
I'll try it right away. Thanks
@sledge
u forgot to change the version number in the first post.
tekko
Post by tekko »
For torrents containing a list of trackers:
If one of the trackers is an invalid address(just some text) or begins with dht:// , they will be filtered as trackerless.
[quote="tekko"]
Can you link to such a torrent or PM me?
Superb release with a huge changelog! Thanks to everyone who has put their work into it, special thanks to sledge.
Install it, love it :)!
100%
Post by 100% »
[quote="Nemo"]
Install it, love it :)![/quote]
Exactly, nicely said! Even Shakespeare himself couldn't have said it better! :D
Thanks, guys, keep up the brilliant work!
pesqb
Post by pesqb »
Thank you all so much for this most anticipated release! Loads much faster and is easy on the eyes. Trackers panel is awesome. Can't wait to switch definitely from 3.1.x.
tekko
Post by tekko »
@sledge
When u have time, can u make a special build with 0.16.x?
I want to use it when responsiveness is needed. i.e. rechecking, editing trackers, changing paths, etc.
Pausing 2-3 seconds once in a while is annoying when doing such tasks.
I don't know if the problem is coming from big torrents whose size go up to 200GB.
Right now I wouldn't want to remove them and do tests. Rechecking my whole list is just too time consuming.
Thanks.
xpsp3 x86, 3.x ram, i5 ivy
Is there something that I can test for you tekko? I got a system with i5 ivy too (i5 3570k @4.2Ghz).
Why are you using XP still mate? Just wondering :).
tekko
Post by tekko »
[quote="Nemo"]
It seems easier to manage files on xp, maybe I am just used to it. And some software runs better on xp. i.e. http://foldersize.sourceforge.net/
I am using drives running on "Acronis Virtual Disk Bus," due to the size limit that 32bit OS has... I don't know if it has an effect on qbt performance...
But then, the alpha build with libtorrent 0.16.x is fine.
The builds with libtorrent 1.0.x does get me more source and let me finish torrents that stalled for a long time though...
So I am trying to use both... libtorrent 1.0.x when I don't need to access the gui...
I really appreciate your kindness @Nemo
Just use "SpaceSniffer". :P
FliessendWasser
Post by FliessendWasser »
Thanks for releasing the new and awaited version!
I tried out the beta for some time, but switched back as it was a bit unstable, but running the updated version I see that you guys made some important fixes and changes, which proves that qBittorrent is a reliable and stable program :)
For now it's doing its work more than fine as it should, and that's chilling.
Thank you again!
tekko
Post by tekko »
Not what I would prefer, but thanks anyway.  ;)
After using it since release my experience so far.
Very stable. No bugs, no crashes, no problems, no connection/download/upload issues, nothing that I experienced so far that would influence my speeds/overall performance. Letting it run intensively for 3/4 days straight with only seeding tasks goes all very good.
Only something very small: I sort my torrents at alphabet, sometimes when I start qBittorrent all torrents are mixed. Pressing the ''Name'' column fixes this.
If there is something (if im using those features) that I can test for anyone let me know.
