! DO NOT REPORT BUGS ON THE FORUMS
Locked
We have a bugtracker for this purpose: https://github.com/qbittorrent/qBittorrent/issues
  • If you do not suspect your issue to be a bug - because it worked before, etc. - then of course, you are free to post.
  • If you need help tracking down an issue so you can make a detailed bugreport, you are free to post.
  • If you know it is a bug, yet you open a topic, the topic will be closed.
Additional:
If you do not what the difference between a support problem and a genuine 'bug' ... Read >> https://github.com/qbittorrent/qBittorrent/wiki/What-is-a-bug
Locked
