Add torrent dialog doesn't shows options
metrolan
Post by metrolan »
Hi!.
I'm a bit confused  :o
My system: micro-PC Mirabox (headless server, Archlinux arm), qBittorrent version 3.2.0 compiled in the server (qbittorrent-nox)
Using web interface from remote computers.
The problem: it is supposed that clicking the "+" icon, it will drop a dialog where I should find options like path to download the torrent and so, but I get only the dialog you can see in the attached picture
What am I doing wrong?
ciaobaby
Re: Add torrent dialog doesn't shows options
Post by ciaobaby »
Expecting a GUI action to occur when using the web UI.
metrolan
Post by metrolan »
Well, then I'm not wrong:
From the wiki:
qBittorrent-nox ships a feature-rich Web UI that is almost identical to qBittorrent graphical user interface.
At least, I'm almost right  ;)
Where can I find the differences?. It seems that there are a few.
ciaobaby
Post by ciaobaby »
Also on the Wiki;
https://github.com/qbittorrent/qBittorr ... umentation
metrolan
Post by metrolan »
Also on the Wiki;
:D :D Fine!
Now seriously, it is not exactly what I'm looking for, 'cause I have no plans at the moment to build a WebUI extension or something like that. Anyway, it is a good point to start learning about, but I've installed qBittorrent on my desktop to see the GUI and the differences with WebUI.
So said, I have another question, maybe worth another thread: Is it possible to connect qBittorrent to a remote core?. I mean, not to do this with the current release, but if the code is such that it can be implemented in the future. Something like Deluge does, for example.
ciaobaby
Post by ciaobaby »
Define; "Remote core" if you do not mean running the GUI as a 'Thin Client,' for a remote service.
metrolan
Post by metrolan »
Well, something like that. But I think that is easiest to modify qBittorrent to give the possibility to connect GUI to a remote qBittorrent (a --nogui compilation, mainly) than to dettach a completely separate GUI program.
