Great software and since I research in many computers ... this one is a challenge.
I have this computer with 11.10 ... because if I upgrade Ubuntu ... no video.
And with qbitt. <= 3.1.2 all versions compile ok and work great!!!!!!
The O.S.
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 11.10
Release: 11.10
Codename: oneiric
The software:
qbittorrent-3.2.0.tar.xz
libtorrent-rasterbar-1.0.4.tar.gz
Boost 1.46.1
Qt is
qmake -v
QMake version 2.01a
Using Qt version 4.7.4 in /usr/lib/x86_64-linux-gnu
So I installed in a dir.
bin/qmake -v
QMake version 2.01a
Using Qt version 4.8.6 in /qtttttttttttttt/lib
/qtttttttttttttt/bin/qtdemo work all the demos.
In qbittorrent-3.2.0
./configure
checking whether to enable the WebUI... yes
checking whether Qt5 should be enabled... no
checking for /qmake... no
checking for /qmake-qt4... no
checking for Qt4 qmake >= 4.8.0... not found
configure: error: Could not find qmake
I changed
./configure QT_QMAKE=/qtttttttttttttt/bin
checking for /qtttttttttttttt/bin/qmake... yes
checking for Qt4 qmake >= 4.8.0... /qtttttttttttttt/bin/qmake
checking whether QtDBus should be enabled... yes
checking for QtDBus >= 4.8.0... not found
configure: error: Could not find QtDBus
Why?
./configure QT_QMAKE=/qtttttttttttttt/bin --disable-qt-dbus
checking whether QtDBus should be enabled... no
checking for boostlib >= 1.35... yes
And "make" work ...
But when
src/qbittorrent -v
src/qbittorrent: error while loading shared libraries: libtorrent-rasterbar.so.8: cannot open shared object file: No such file or directory
Please your comments.
Thanks in advance,
Neuron
qbittorrent-3.2.0 in Ubuntu 11.10
Re: qbittorrent-3.2.0 in Ubuntu 11.10
Ditto on that problem for Mint 16.src/qbittorrent -v
Installing using apt-get with qbittorrent-team PPAs has no such problem. (libtorrent 16.13 showing in libraries)
PPAs are
Stable: https://launchpad.net/~qbittorrent-team ... ent-stable
Unstable: https://launchpad.net/~qbittorrent-team ... t-unstable
Thank you for your quick answer.ciaobaby wrote:Ditto on that problem for Mint 16.src/qbittorrent -v
PPAs are
Yessssssss I know I can use the ppa ...
But I prefer ... compile ... and libtorrent 0.16.13
Now is 1.0.4
This is strange ...
In "make":
g++ use
-I/usr/local/include/libtorrent
-I/qtttttttttttttt/include/QtGui
-I/qtttttttttttttt/include/QtNetwork
-I/qtttttttttttttt/include/QtCore
-I/qtttttttttttttt/include/QtXml
Whats the problem with
make use QtGui, QtNetwork, QtCore, QtXml ...
and miss QtDBus ...?
Regards,
Neuron
I was having the same issue and I found this forum post:
index.php/topic,3365.msg16414.html#msg16414
I apt-get install libqt4-dev and that solved my compile issue.
Hope this helps!
Hope this helps!
[quote="neuron"]
It works!!! ...
"libtorrent-rasterbar-0.16.17.tar.gz" compile and run.
The app don't use my fonts and my theme from Ubuntu ...
Why?
Small letters ... :-( :-( :-(
- libtorrent-rasterbar-1.0.4 and libtorrent-rasterbar-1.0.1
Compile but
src/qbittorrent -v
ldconfig -p | grep torrent
libtorrent-rasterbar.so.7 (libc6,x86-64) => /usr/local/lib/libtorrent-rasterbar.so.7
libtorrent-rasterbar.so (libc6,x86-64) => /usr/local/lib/libtorrent-rasterbar.so
ldd src/qbittorrent
linux-vdso.so.1 => (0x00007fff2e75f000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f6d4a109000)
libtorrent-rasterbar.so.8 => not found
I don't have libtorrent-rasterbar.so.8 => /usr/local/lib/
Solution "ln -s" in one lib ex. /lib/x86_64-linux-gnu/ or /usr/lib/x86_64-linux-gnu/
When we configure and compile .... he don't create an entry to /usr/local/lib ....?
Very w.
I have all source code - Qt, libtorrent and qbittorrent, ... !!!
Thanks in advance,
Neuron
It works!!! ...
Why?
Compile but
src/qbittorrent -v
ldd src/qbittorrent
Very w.
Thanks in advance,
Neuron
[quote="neuron"]
And libtorrent-rasterbar 1.0.5 is working too :-) :-) :-)
Can you explain the app don't use my fonts and my theme from Ubuntu ... ?
Why?
And qbit. store the Applications icons in ...
I saw only /usr/local/share/icons/hicolor/XXxXX/apps/
Thanks in advance,
Neuron
Why?
Thanks in advance,
Neuron
