Restricting web UI to LAN access only
For security purposes, how do I restrict the web UI to only allow access for those connecting through LAN only, and not the Internet? i.e. 192.168.1.0/24
Re: Restricting web UI to LAN access only
Don't forward the Web UI port through your router.
[quote="ciaobaby"]
Does qBittorrent use UPnP to automatically forward the Web UI port in the router? If not, then I'm guessing the port is not forwarded at all, since I haven't edited the router settings. (If that's the case, are only those connecting through LAN allowed to access the web UI?)
Also, is there a way to secure this through qBittorrent only? I'm talking about something like in uTorrent, where I was able to configure it by setting it like this:
If you have UPnP enabled it will, otherwise it won't.
Tools -> Options -> Web UI.
