Adding Multiple User
mrtkx
Post by mrtkx »
Hello,
1.Is there any possible way to add multiple user in qBittorrent Webui. My aim is to serve it to the clients like a seedbox.
2. Any way to create torrent via webui?
Thanks,
Compass
Re: Adding Multiple User
Post by Compass »
As to question #1, it doesn't seem to be possible. An alternative would be for you to create separate accounts for the people you wish to have access to the qBittorrent Web UI, and in such case you'll have to make separate port forwards for each user to connect to their own qBittorrent Web UI. It wouldn't be a single running instance for all the users, but rather one instance per user. I don't think this is what you want to do.
As for question #2, no idea. Perhaps it's possible to ssh into the machine and create a torrent using the command line? Someone more experienced will be more helpful.
Compass.
ciaobaby
Post by ciaobaby »
No, because anything running in a HTTP: context is NOT allowed access to the local file system at all.
