I can see the qbittorrent-nox process running.
I cannot access QBT webui.
Information...
Service Status:
$ sudo service qbittorrent status
qbittorrent.service - LSB: Starts QBittorrent
Loaded: loaded (/etc/init.d/qbittorrent)
Active: failed (Result: exit-code) since Wed 2015-08-12 18:05:56 PDT; 29min ago
Docs: man:systemd-sysv-generator(8)
Process: 572 ExecStart=/etc/init.d/qbittorrent start (code=exited, status=1/FAILURE)
CGroup: /system.slice/qbittorrent.service
??583 /bin/bash -c /usr/bin/qbittorrent-nox >> /var/log/qbittorrent-nox.log 2>&1
??586 /usr/bin/qbittorrent-nox
systemd[1]: Starting LSB: Starts QBittorrent...
qbittorrent[572]: Logging to /var/log/qbittorrent-nox.log.
systemd[1]: qbittorrent.service: control process exited, code=exited status=1
systemd[1]: Failed to start LSB: Starts QBittorrent.
systemd[1]: Unit qbittorrent.service entered failed state.
systemd[1]: qbittorrent.service failed.
systemd[1]: Stopped LSB: Starts QBittorrent.
[b]Manually starting QBT service:[/b]
[b]$ sudo service qbittorrent start[/b]
Job for qbittorrent.service failed. See "systemctl status qbittorrent.service" and "journalctl -xe" for details.
[b]$ journalctl -xe[/b]
bittorrent[1806]: Logging to /var/log/qbittorrent-nox.log.
-- Subject: Unit qbittorrent.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit qbittorrent.service has failed.
-- The result is failed.
polkitd(authority=local)[693]: Unregistered Authentication Agent for unix-process:1778:196431 (system bus name :1.127, object p
sudo[1810]: jake : TTY=pts/1 ; PWD=/home/jake ; USER=root ; COMMAND=/usr/sbin/service qbittorrent start
sudo[1810]: pam_unix(sudo:session): session opened for user root by jake(uid=0)
polkitd(authority=local)[693]: Registered Authentication Agent for unix-process:1811:197027 (system bus name :1.130 [/usr/bin/p
-- Subject: Unit qbittorrent.service has begun start-up
-- Unit qbittorrent.service has begun starting up.
qbittorrent[1836]: Logging to /var/log/qbittorrent-nox.log.
polkitd(authority=local)[693]: Unregistered Authentication Agent for unix-process:1811:197027 (system bus name :1.130, object p
sudo[1810]: pam_unix(sudo:session): session closed for user root
