[quote="ciaobaby"]
#2639
#2428
Hi, Ciaobaby!
Good morning!
Thanks a lot for your kindness doing such a search for my doubt. However, let me make you one question because i really didn't understand what it means those posts under the references you gave me, mainly the first one. I've read both, but i didn't understand whether there is already a solution or not for the problem i presented to you.
Under
https://github.com/qbittorrent/qBittorrent/issues/3639 it seems that someone is pointing to the solution for this problem. But i really didn't get the way to do what he describes there. May be because images put there, containing explanations about the right place to do it, are not visible anymore. Can you help me?
Thanks a lot for your kindness.
Have a good day! Big hug.
