Where is the log stored?
I have the configuration setting:
ExecutionLog\enabled=true
I checked /var/log/ but nothing like qbittorrent shows up.
QBT daemon
QBT v3.3.0 beta
Execution Log Location (v3.3.0 beta)
Re: Execution Log Location (v3.3.0 beta)
[quote="snakyjake"]
From looking through the qbittorrent source code and sudo 'grep'ping' a current log entry, from the file system root '/' downwards .... .... on two different machines that qbittorrent is running on, the answer appears to be, ... ...
"nowhere in particular".
Now it if is a 'virtual' log ... what a waste of running memory that is!
