A small usability change that could make a big difference
Sp4rkR4t
Post by Sp4rkR4t »
One small niggle I have noticed since changing to qBittorrent is that when I use call up the extract files.. dialog it correctly focuses on the location box and if I use the arrow keys will allow me to scroll through my previous choices but will not do the same if I use the scroll wheel on my mouse, something that would greatly increase usability as it is a extremely common option for using dialog boxes of that type. Like I said a small change that would make a large usability difference.
ciaobaby
Re: A small usability change that could make a big difference
Post by ciaobaby »
?? The "extract files.. dialog" is what exactly??
