I/O error
ismanpa
I/O error
Post by ismanpa »
Hello,
I have lent an external drive to a friend.  The drive has a lot of downloads - finished and not finished.  When I start QB, i naturally get I/O errors.  The strange thing is that I have them for another drive which is connected.  Some of the torrents even start anew even though they are completed.  I cannot possibly manually delete hundreds of torrents like in the previous sentence.  What should I do.
Another problem is the the client starts too slow.  I have been thinking to migrate to Tixati, but I love QB!
Please, help!
Thank you.
Re: I/O error
Did you get these IO errors before you lent it to said friend?
> I/O Errors
Check the SMART data, just in case.
1) Open a terminal
2) sudo smartctl -a /dev/sdX
X = portable drive's letter, Linux auto-assigns it.
If you have one drive in your PC, then it will /dev/sdb.
Two drives and this is the third? /dev/sdc. And so on.
Check the "reallocated sectors" and things like that in the output.
ismanpa
Re: I/O error
Post by ismanpa »
jojo@down ~ $ sudo smartctl -a /dev/sdb
sudo: smartctl: command not found
jojo@down ~ $ sudo smartctl -a /dev/sdd
jojo@down ~ $ sudo smartctl -a /dev/sda
jojo@down ~ $ sudo smartctl -a /dev/sde
Re: I/O error
Then do this, then what I said before:
$ sudo apt-get update
$ sudo apt-get install smartmontools
ismanpa
Re: I/O error
Post by ismanpa »
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.16.0-38-generic] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     WDC WD20NPVX-00EA4T0
Serial Number:    WD-WX61A85632TL
LU WWN Device Id: 5 0014ee 2b738d23a
Firmware Version: 01.01A01
User Capacity:    2,000,398,934,016 bytes [2,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5200 rpm
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Mon Feb  1 23:21:47 2016 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(37440) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 413) minutes.
Conveyance self-test routine
recommended polling time: 	 (   5) minutes.
SCT capabilities: 	       (0x7035)	SCT Status supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   218   208   021    Pre-fail  Always       -       4075
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       260
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       81
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       78
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       8
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       637
194 Temperature_Celsius     0x0022   126   110   000    Old_age   Always       -       26
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
jojo@down ~ $ sudo smartctl -a /dev/sdc
Serial Number:    WD-WX91E943W54V
LU WWN Device Id: 5 0014ee 260eb77b3
Local Time is:    Mon Feb  1 23:22:13 2016 EET
					was never started.
					been run.
data collection: 		(36000) seconds.
					command.
					power-saving mode.
recommended polling time: 	 ( 397) minutes.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       1
  3 Spin_Up_Time            0x0027   206   193   021    Pre-fail  Always       -       4691
  4 Start_Stop_Count        0x0032   099   099   000    Old_age   Always       -       1660
  7 Seek_Error_Rate         0x002e   100   253   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1577
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       459
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       151
193 Load_Cycle_Count        0x0032   196   196   000    Old_age   Always       -       13240
194 Temperature_Celsius     0x0022   124   105   000    Old_age   Always       -       28
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       1
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Model Family:     Seagate Barracuda 7200.12
Device Model:     ST31000528AS
Serial Number:    6VP0BMQC
LU WWN Device Id: 5 000c50 013e8a38e
Firmware Version: CC35
User Capacity:    1,000,204,886,016 bytes [1,00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Mon Feb  1 23:22:19 2016 EET
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/213891en
Warning: This result is based on an Attribute check.
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
					been run.
data collection: 		(  617) seconds.
					command.
					power-saving mode.
recommended polling time: 	 (   1) minutes.
recommended polling time: 	 ( 192) minutes.
SCT capabilities: 	       (0x103f)	SCT Status supported.
					SCT Error Recovery Control supported.
SMART Attributes Data Structure revision number: 10
  1 Raw_Read_Error_Rate     0x000f   116   099   006    Pre-fail  Always       -       109146834
  3 Spin_Up_Time            0x0003   095   094   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       451
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       22
  7 Seek_Error_Rate         0x000f   072   060   030    Pre-fail  Always       -       4312675457
  9 Power_On_Hours          0x0032   052   052   000    Old_age   Always       -       42777
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       453
183 Runtime_Bad_Block       0x0000   100   100   000    Old_age   Offline      -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   078   000    Old_age   Always       -       399444279576
189 High_Fly_Writes         0x003a   096   096   000    Old_age   Always       -       4
190 Airflow_Temperature_Cel 0x0022   071   047   045    Old_age   Always       -       29 (Min/Max 19/40)
194 Temperature_Celsius     0x0022   029   053   000    Old_age   Always       -       29 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   029   021   000    Old_age   Always       -       109146834
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       228930346829426
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1308448298
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       3505618908
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%         0         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Local Time is:    Mon Feb  1 23:23:47 2016 EET
					been run.
					command.
					power-saving mode.
  1 Raw_Read_Error_Rate     0x000f   116   099   006    Pre-fail  Always       -       109411827
  7 Seek_Error_Rate         0x000f   072   060   030    Pre-fail  Always       -       4312675482
195 Hardware_ECC_Recovered  0x001a   029   021   000    Old_age   Always       -       109411827
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       15655155811954
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       3505859042
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Re: I/O error
Now there is only one drive having health problems, according to SMART.
This drive:
Is dying/dead.
Even a single reallocated sector count means you have to backup ASAP and get a replacement.
There is also this:
