Upload and download speed graph
Having used the windows 10 version of qBt, i have become quite accustom to the upload and download speed graph, giving you much information to hand. Since changing to Linux and continuing to use qBt, i've noticed that their version doesn't contain said graph. Can anyone shed any light if they know this has been flagged before, and possibly going to get rectified in future updates? Thanks!
Re: Upload and download speed graph
Are you using the old/out of date qbittorent from ubuntus PPA? (version 3.1 instead of 3.3.4)
If so try updating, either add the stable/unstable branch from here: https://launchpad.net/~qbittorrent-team
as a ppa to your sources, or download&install tarball from here: http://sourceforge.net/projects/qbittor ... z/download
If you're using 3.3.4 and it isnt showing the speed graph, im not sure why.
Aaaah... Elementary... Thought i would've been prompted for an auto update if there were newer versions...
Thanks for the advice, i'm happy now!
[quote="jocksrock82"]
Not on linux friend!
Well at least not when the source PPA doesnt know about the new version..
