Placement of delete popup window
Dexter10255
Post by Dexter10255 »
I have 3 monitors and I keep qBittorent off the middle monitor. Whenever I right click to delete a torrent in qBittorent the confirmation window to delete the torrent pops up in the center of the middle monitor, very far away from where my mouse pointer is. I could go into settings and change it so that I do not need to confirm when deleting torrents but that doesn't seem to delete the files with this option. I have the box checked to delete the files off HDD but since no window pops up it doesn't do it. My suggestion is can you make it so the delete popup remembers it's position or have it so the popup will only popup inside the center of program window. Thank You. I know this is a small problem but it's very annoying for me and I can't seem to find a way to change it.
KitKat
Re: Placement of delete popup window
Post by KitKat »
https://github.com/qbittorrent/qBittorrent/pull/3858
this fixes that issue, it hasnt been merged yet/hopefully it will be merged in the 3.3.5 release.
(so i can stop merging it into my build and start using the master again..)
Dexter10255
Thank you. :D
