Security issue about favicon.ico
hammer1
Post by hammer1 »
Hi. There's some favicon.ico files (those icons used by trackers) that are infected. I'd like to ask you gently -but urgently- to find a way to protect users from that kind of vulnerability. My suggestion is to make optional the display of images referred to favicon.icon files.
Thank you in advance.
tekko
Re: Security issue about favicon.ico
Post by tekko »
Switeck
Post by Switeck »
I second being able to disable favicons!
https://github.com/qbittorrent/qBittorrent/issues/5286
[Wishlist] Option to disable Tracker Favicons therefore all trackers to use a default qB one #5286
