[quote="Switeck"]
My greatest concern about releasing a guide/chart showing "never exceed these" values at listed upload speeds for qBitTorrent...is that's
exactly the values lots of people will end up using, when instead they shouldn't be using values anywhere near them!
Worse, thanks to the use of qBitTorrent's Scheduler's lower speed settings (which seem to default to 10 KB/sec DL and UL) and/or manually lowering upload speed later...people would greatly exceed the "never exceed these" values and might not even know it.
qBitTorrent doesn't give any warning when horrible settings are used with it, nor does there seem an easy way to add that.
Internally qBitTorrent seems to have minimal sanity checks for impossible values -- such as when someone has queueing set to limit max active uploads to 0, or global max upload slots set to 0, or per-torrent connection max greater than global max connections.
If you want highest possible download speed, don't look for "
Magic BitTorrent Settings" -- instead look for
Good Torrents!
YouTube 'uTorrent Speedup' videos tend to be the
WORST, often with impossible settings combinations -- such as more connections per torrent than globally allowed or more downloading torrents than max active torrents.
If you are connected to 50 peers but only uploading to 4 (because qBitTorrent is set to 4 upload slots max per torrent), don't expect much download speed from the 40+ peers you're NOT uploading to! Those 40+ peers may also be connected to 50 peers but uploading to only 4 peers at a time, so they almost never upload to you...unless you're uploading to them faster than most of their peers. Your upload slots are "given out" to the peers uploading the fastest to your peer, plus 1 "roaming" optimistic unchoke upload slot that tries to find a new faster/fastest peer. The few nuts that set their upload slots really high often upload to every peer...but at <1 KB/sec each!
This is why adding more connections per torrent may not increase download speeds.
If you have bad speeds even with good torrents, perhaps your
ISP is to
blame? (Some ISPs want to take over the internet by demanding money from websites they don't own and their customers use heavily.)
So what you're saying Switeck, is we should use QBTs' default rate limits, connection limits, ect . Just don't mess with them and we will generally get the highest up/down rate our isp allows?
