QB 3.3.7 install on Ubuntu Server 16.04
zanophol
Post by zanophol »
I installed from the ppa stable repo, and while QB starts just fine, and I am able to change its settings, I am unable to debug a problem where it starts to download a torrent and then stops. I would love to be able to examine a log file to find out the issue. However, following the guide below, I was unable to find a log file -- nor am I able to ascertain how to force one to be created.
Might anyone know how to resolve this?
https://www.linuxbabe.com/bittorrent/qbittorrent-web-ui-ubuntu
doctoralex
Re: QB 3.3.7 install on Ubuntu Server 16.04
Post by doctoralex »
First try to start manually the qb without the systemd. Second the log file should be on .local/share/data/qBittorrent/logs/
Enable the Execution Log and check what happens.
Are you sure you have write/permission access to your folder?
