With the Mac client, is there a way to change the double-click to rename the downloading file?
I find that I like to rename almost all the files I download and its slow to have to right click and select rename.
If not possible could it please be added to the list of feature requests?
Double click to rename
Re: Double click to rename
I see you opened an issue at Github too which is the correct place to make feature requests,
https://github.com/qbittorrent/qBittorrent/issues/6086
Yep. I couldn't work out how to label it Wishlist though, I assume I can't do that.
You cant tag things, but nothing will stop you from merely adding [Wishlist] in the title topic ;p
