enable advanced saving management in qbittorrent-nox
king_dick
Post by king_dick »
Hi!
I'm trying to get qBittorrent to download my torrents into folders for the categories each torrent is set  to, but I run it on an headless server using qbittorrent-nox and I can't find any way in the webui or the qbittorrent.conf file to set advanced saving management as default for torrents.
I'm running qBittorrent 3.3.10 from the qbittorrent-stable repo on Ubuntu server 16.04.
Thanks for any help you can provide!
RFinn
Re: enable advanced saving management in qbittorrent-nox
Post by RFinn »
Did you ever find a solution for this? I'm running into the same thing.
RFinn
Post by RFinn »
Ended up finding a solution for this.
Posted here https://qbforums.shiki.hu/index.php/topic,4955.0.html
