Using NOX WebUI over VPN
shylissyr1
Post by shylissyr1 »
Hi all,
is there a way to configure qBittorrent NOX so that only clients within a specific IP range can access the WebUI?
If so, how can i do it?
qBittorrent version: v3.3.10, OS: Ubuntu 16.04 x86 (server edition).
Re: Using NOX WebUI over VPN
You could easily use "ufw" for this.
https://www.digitalocean.com/community/ ... d-commands
It's not hard to learn (in fact it is really simple, it is designed to be simple, after all.)
Simply:
1) install ufw
2) allow your SSH port or whatever you use to reach your server
3) set the rule for qbittorrent's webUI port, to only allow connection from X IP
4) call it a day
It's a 10 minute task.
- You could also use SSH Port forward simply. This is also a common practice.
shylissyr1
Thanks!
