Web-UI locked on Qbittorrent-nox (Raspberry Pi 3B - RASPBIAN JESSIE) [SOLVED]
harryjohnsonab
Post by harryjohnsonab »
Hi.
I seem to have locked myself out of the QBittorrent WebUI.
I have tried resetting the password of the user (i think its qbtuser) that is used for the login - using passwd.
I have also tried adding this*: WebUI\Password_ha1=@ByteArray(5ebe2294ecd0e0f08eab7690d2a6ee69) - to /home/qbtuser/.config/qBittorrent - sudo nano qBittorrent.conf
* https://github.com/qbittorrent/qBittorrent/wiki/Web-UI-password-locked-on-qBittorrent-NO-X-%28qbittorrent-nox%29
Adding: locked=false or setting WebUI\LocalHostAuth=false is no good.
Trying to login in with "admin - adminadmin" or "qbtuser - secret" and finally "admin - secret" is no good either (also trying a bunch of my old passwords).
Here is the output of my qBittorrent.conf file:
Connection\ProxyType=-1
Connection\Proxy\IP=0.0.0.0
Connection\Proxy\Port=8080
Connection\ProxyPeerConnections=false
Connection\Proxy\Authentication=false
Connection\Proxy\Username=
Connection\Proxy\Password=
IPFilter\Enabled=true
IPFilter\File=/home/pi/biglist.p2p
WebUI\Port=8080
WebUI\Username=admin
WebUI\LocalHostAuth=true
WebUI\HTTPS\Enabled=true
DynDNS\Enabled=false
DynDNS\Service=0
DynDNS\Username=
DynDNS\Password=
DynDNS\DomainName=changeme.dyndns.org
Scheduler\start_time=@Variant(\0\0\0\xf\0\0\0\0)
Scheduler\end_time=@Variant(\0\0\0\xf\x1I\x97\0)
Scheduler\days=0
Connection\alt_speeds_on=false
[LegalNotice]
Accepted=true
[AutoRun]
enabled=false
program=
Thank you a lot for any help/answers provided  ;D!
Let me know if you would like more information.
Greetings,
- Harry.
Last edited by harryjohnsonab on Sun Jan 22, 2017 1:03 pm, edited 1 time in total.
harryjohnsonab
Re: Web-UI locked on Qbittorrent-nox [Raspberry Pi 3B - RASPBIAN JESSIE]
Bump.... Anyone?  ???  :-\
harryjohnsonab
Alright.. I decided to do a complete restore! If anyone is looking for a great (but old) guide on how to setup a "torrentbox" with Qbittorent - check this one out: https://www.youtube.com/watch?v=5pdm325bYVQ&feature=youtu.be  :)
