Use same port as both main listen port and webui port
Is it possible to use same port as both main listen port and webui port?
Re: Use same port as both main listen port and webui port
As a programmer I can tell you, it's not recommended to use the same listen port for two different services, so I seriously doubt that it's possible.
No, it's not possible. Sadly.
Both are "listening ports".
ok, thank.
I'm used to use µTorrent, and by default it uses the same port number both as main listening port and as webUI port.
