Cannot run Java program
noba
Post by noba »
Hi, i'm new to this forum, and torrenting in general. Though i know the basics and how to do it safely, ect, ect.
Anyway, onto my question:
I recently torrented bitwig studio, and found that it actually works. (Yes i've scanned it, ect)
Except, i'm struggling to generate a keygen. The one that comes with it, plus any keygen.class that i download doesn't work. At all. It doesn't even load.
I've installed java, and done whatever i can to get it get it to work, but it just won't. Every time i try to load it, i get the error "Class not registered". I'd imagine there should be a simple fix to this, and i'm just being stupid, but i'm starting to give up
Re: Keygen.class issue
Well this is not a qBittorrent issue, nor it is related to Windows.
The error means that it's a problem with the Java program (which is your keygen, I suppose?).
Are you sure you are trying to load it up the right way?
Is it a .JAR file?
If so, you can start it with cmd and using "java -jar filename.jar".
Ps.: I modified the topic's title as this is more about Java, than a keygen.
By the way I would use a Virtual Machine to run such things - you should never ever trust keygens and such.
