how can i set qBittorrent to share for several ISPs?
astrocrab
Post by astrocrab »
i have a system under ubuntu with several NICs connected to different ISPs.
how could i share files effectively across all system IPs?
thank you.
Switeck
Re: how can i set qBittorrent to share for several ISPs?
Post by Switeck »
Even with clever binding and announcing on a different ip than you make outgoing connections on, you'll probably be unable to get qBitTorrent to use more than 2 internet connections at once...and even the 2 it does use will be unreliably used.
[quote="astrocrab"]
thank you.
You could run several copies of qBittorrent, sharing the same file?
Just an idea, all binding to separate NIC.
Firejail might be useful too.
