Pretty forward
People who have concerns about disk usage, and have multiple torrents (1000+) and destinations/disks for the torrents, needs to know how much disk is being used
also, if a specific drive will support the [not yet] completed torrents
[SUGGESTION] Show size of ALL selected torrents
Re: [SUGGESTION] Show size of ALL selected torrents
Not a bad idea -- but where would qBT show this?
Would it be a little 'pop-up' notification like for when a download completes and disable-able as well?
Or would it appear as a separate column or at the very bottom on the status bar?
I would advice you to put it over here at https://github.com/qbittorrent/qBittorrent/issues where it gets more attention. Put [Wishlist] infront of the issue and write it down as detailed as possible like Switeck says.
Thanks almmiron, I would advice you to blur the torrent names for your own safety. Not everyone needs to know what you're downloading but thats up to you
And welcome by the way.
Issue link:
https://github.com/qbittorrent/qBittorrent/issues/7025
Issue link:
