Some time ago, I updated and ever since then I have been unable to determine how to filter/not display permanently search results of 0 B. Essentially since the change was implemented after every search I must manually select up arrow to the right of Size to "hide" them.
A feature like is found in options>Transfer List> Hide Zero and Infinity Values would be helpful, one checkbox and forget it.
If I have overlooked a setting, I would appreciate someone to point me in the right direction. Thank you!
Rosco
