Unbanning Peers?
blerns
Unbanning Peers?
Post by blerns »
After right clicking a peer in the Peers tab and clicking "Ban peer permenantly", is there a way to unban that peer?
Switeck
Re: Unbanning Peers?
Post by Switeck »
You have to edit qBT's configuration file.
It's a pain to do.
Did you read qBT's FAQ on how?
blerns
Post by blerns »
Thank you. I had looked over the FAQ but must have glanced over that portion. I found it in the qBittorrent.ini under Preferences/IPFilter.
Thanks again.
mooch0825
Post by mooch0825 »
Can someone please tell me in a little more detail how to unban peers? I am not sure if I am savvy enough to know how to edit a config file on my own. My friend was messing around and banned a ton of peers. Let's just say that didn't produce good results. Thank you!
Chieftl
Post by Chieftl »
mooch0825 wrote: Thu Sep 28, 2023 5:20 pm Can someone please tell me in a little more detail how to unban peers? I am not sure if I am savvy enough to know how to edit a config file on my own. My friend was messing around and banned a ton of peers. Let's just say that didn't produce good results. Thank you!
If question still actual: qBittorrent config file is named qBittorrent.conf and located in %APPDATA%\qBittorrent (Windows) or ~/.config/qBittorrent (Linux).
You should open it by text editor and find line started by IPFilter\BannedIPs=... - here is list of banned ips
