error during search
grogorio
error during search
Post by grogorio »
I'm running qbittorrent v3.3.1 on ubuntu gnome 16.04.
Seems I have both Python 2 and 3 installed.
I'm getting an error when using the search tab:
Status: An error occured during search...
Any ideas on how to fix this?
Re: error during search
As im not known with ubuntu at all, maybe this Github issue could solve your problem: https://github.com/qbittorrent/qBittorrent/issues/445
Can you try this?
r1239740
Post by r1239740 »
Hi. I had the same problem. I solved it following this advice: https://qbforums.shiki.hu/index.php/topic,5254.0.html
It says that debian/ubuntu users should use the PPA compilation.
sudo add-apt-repository ppa:qbittorrent-team/qbittorrent-stable
sudo apt-get update
The search engine is fully functional right now. I'm on Ubuntu 16.04 xenial, hope it helps  :)
grogorio
Post by grogorio »
Thanks r1239740, that solved it for me  ;D
uPapa
Post by uPapa »
Hi guys,
I've already the same problem and the sugestion of the new repository dosent work for me.
I've qbittorent 4.0.3 installed after added the sugested repository with the command
sudo apt-get install qbittorrent-stable
There are no search results despite de inumerous DHT nodes. My OS is Xubuntu (Ubuntu Xenial 16.04.3 LTS)
Do you have another sugestions?
Thanks in advance2018
