qBittorrent doesn't run anymore.
Jerfus
Post by Jerfus »
This is a problem which just began yesterday, prior to that it was working perfectly. Everytime I try to run it, it just shows the splash screen for a few seconds and then nothing, I've already checked and there's no process running, it doesn't open at all.
Jerfus
Re: qBittorrent doesn't run anymore.
Post by Jerfus »
Thanks, but I had already tried that without much hope. It doesn't even open to tray, and I even tried with the grep | lsof -torr i and no process is running, neither there nor through the system monitor.
Zenny422
Re: qBittorrent doesn't run anymore. (My Solution)
Post by Zenny422 »
I have the same problem. A splash screen pops up for a few seconds and then it dies UUugggghh  This happens from time to time with older Ubuntu Distros.aswell. Currently using Oneiric 11.10 64bit  Help !!!!!!  Ok this is what terminal said  ----> Couldn't set environment variable...
qbittorrent: symbol lookup error: qbittorrent: undefined symbol: _ZN10libtorrent7sessionC1ERKNS_11fingerprintEii      ok My Solution was  to remove libtorrent-rasterbar 6 from synaptic package manager. Reinstalled qbittorrent from site not Software Center. It came back Hoooray !!!!
freddybob
Post by freddybob »
I have the same problem on the same OS (Ubuntu 11.10 64bit).
Has anyone found a fix or workaround?
(qbittorrent:14139): Gtk-WARNING **: Unable to locate theme engine in module_path: "pixmap",
freddybob
Post by freddybob »
This bug report led me to believe there was a problem with libtorrent-rasterbar6 from having qBittorrent and Deluge both installed.
I fixed the conflict by:
sudo apt-get remove libtorrent-rasterbar6 deluge qbittorrent
sudo apt-get autoclean
sudo apt-get install deluge qbittorrent
Jerfus
Post by Jerfus »
Thank you for the tip but it didn't work, it's the same as before.
freddybob
Post by freddybob »
Maybe it's not libtorrent-rasterbar6 causing the conflict on your system.  I'd try removing then re-installing libtorrent*.
Do you have both qBittorent and Deluge installed?  Do you need both?
loki
Post by loki »
Another thought, if you do have both installed, is it possible qbittorrent and deluge are both requesting a different version of libtorrent? So one is causing a conflict with the other.
