unme
Post
by unme » Mon Oct 31, 2011 4:37 pm
./configure --disable-gui
Configuring qbittorrent ...
Verifying Qt 4 build environment ... fail
Reason: Unable to find the 'qmake' tool for Qt 4.
Be sure you have a proper Qt 4.0 build environment set up.
<skip>
is it still require Qt?
qt-everywhere-opensource-src-4.7.3.tar.gz 203 MB
to compile guiless 3MB program?
Posts: 3044 Joined: Wed Jul 07, 2010 6:14 pm
Post
by Peter » Mon Oct 31, 2011 10:58 pm
Yes, the headless version needs Qt too.
Try AwesomeWM or other applications. They need a huge ton of libraries.
(Also, try to compile KTorrent for example. =))
Brogyi
Post
by Brogyi » Sat Nov 12, 2011 9:22 am
My installation used the next dependencies:
sudo apt-get install build-essential libtool automake autoconf subversion pkg-config
sudo apt-get install libboost-date-time-dev libboost-dev libboost-filesystem-dev \
libboost-iostreams-dev libboost-program-options-dev libboost-regex-dev \
libboost-serialization-dev libboost-signals-dev libboost-test-dev \
libboost-thread-dev libssl-dev
sudo apt-get install libqt4-dev
Post
by Peter » Sun Nov 13, 2011 12:01 am
[quote="brogyi"]sudo apt-get install libqt4-dev[/quote]
That's what he meant. libqt4-dev is literally Qt.
